400 ford ignition
Old Oct 22, 2016 | 10:47 AM
79f1501ton's Avatar
79f1501ton
400 ford ignition
I have a freshly built 400 that is having problems with the spark. I can put a timing light on #1 and 8. And it will flash like it should then randomly quit for a few seconds. I've already swapped wires around and it stays on 1 and 8. I've also put on a new cap and distributer but it's still randomly not firing. I can't think of any thing else it could be. Any help would be appreciated
Old Oct 22, 2016 | 03:46 PM
79f1501ton's Avatar
79f1501ton
Would bad plugs possibly cause it to randomly not spark when testing it with a timing light
Old Oct 22, 2016 | 05:42 PM
thedopefishlives's Avatar
thedopefishlives
Yes. Anything that stops the spark from going from the distributor to the ground will stop the timing light from blinking. Swap the plugs between cylinders and see if it follows the plugs.
Old Oct 22, 2016 | 07:25 PM
79f1501ton's Avatar
79f1501ton
Thanks I decided to try that before I saw your post and it fixed them. It finally runs like I thought it should have when I built it
Old Oct 23, 2016 | 07:14 AM
Gary Lewis's Avatar
Gary Lewis
Welcome to FTE! And congrats on the new engine and the fix. Well done!
brandonsnider1986
Apr 15, 2013 07:19 PM
jaye
Sep 24, 2008 07:16 AM
builtfordtough13
17
Jul 2, 2008 01:46 AM
re_fill
1978 - 1996 Big Bronco
Oct 4, 2006 06:32 PM
Truckasoras
Mar 30, 2001 05:20 PM
