Swapping a 6.4 or 6.7 starter into the 6.0
#91
From what it looks like, the 6.0/6.4 starters threaded bolt holes are all the same or is it larger for them and they're all the same for the 6.7?
I think what I'd like to do (like what Randy said) is get a 6.7 and drill and tap the lower hole to use the original size bolt in it as long as that wouldn't weaken that mounting ear. That's 10mm by what thread?
Looks good! ^^^ Mine should be here tomorrow
#93
Your right my bad. I can probably find out this weekend when I swap it in. I'm going to drill and tap it to the factory 6.0 size bolt. I'll put a die on it and see what the thread count is. Going to have to anyway to know what size tap and drill bit to use
#95
#97
USPS dropped off a gift today! Like an idiot as I was cleaning it I wiped off half the sticker The numbers were correct though. You can see the one smaller bolt on the bottom. Its in great shape though!
And courtesy of my work I'm borrowing a couple amp meters. I need to test them to make sure they're functioning properly
#98
#99
Ah crud your right. Don't know how that slipped my mind, I just assumed AC since that's what I deal with all day long on motors. I'll have to see if we even have a DC version
#100
My ammeter won't be showing up until Monday. Really trying to figure out what is going on with Amazon lately. 2 day prime take 5 days???
Yep, you need DC amps, and you have to play with them to see how the responce is, if they capture true peak, or miss that. The really good ones seem to be in the $350 range. Bother then that you have to play.
#101
#102
or that the part wasn't fulfilled by Amazon... you need to read carefully.
I bought a .5 micro ceramic filter just before the hurricane. Being somewhat trained in weather forecasting by the Navy, I track each hurricane because the weather guys are incompetent. A water boil is a big deal and always a probability with a large flood type disaster. A ceramic filter will make your water drinkable without boiling, add two 5 gallon buckets, faucet for the bucket and your set. Make all the water your family needs to survive.
I ordered two filters, increased quantity of the order, add to cart, check out...one filled by Amazon, one from the manufacturer, one arrived in two days, one in 5 days, both advertised as Prime. I think they are overwhelmed as well... did you know they even have drop boxes at 7-11? You order on-line and go to a drop box an hour later and open the box (like a post box) and grab your stuff...ONE HOUR!
#103
I've had the delays for some time as well. I get a lot of stuff through AMZN and no matter what I've got I've never seen this type of delay with Prime, and I look for their inventoried stuff. Tonight they dropped in their earnings (Christmas ain't gonna be so good) and I wonder if they are trying to lessen shipping expense. If this continues they are going to loose some business.
#105
You must be in the same location as a fulfillment center to get that?
My starter was ordered late Monday afternoon, delivered to the door Wednesday.
11 12 13 14 15 FORD F350 SUPER DUTY STARTER MOTOR 6.7L DIESEL 386231 | eBay
Not to shabby
Not to shabby
