MPH = RPM
Old Oct 21, 2016 | 07:45 AM
Jim and Austin's Avatar
Jim and Austin
MPH = RPM
Since starting our revitalization our grandsons truck I have been concerned about the 4:27 rear axle ratio. I ran across this formula the other day that would mathematically state the engine RPM at a specified speed. I thought it was interesting and worth sharing. Hope it helps someone else on the site!
Here is the formula:
Speed X gear ratio X 336 / tire diameter
So Austin's truck would calculate as follows:
50MPH X 4.27 X 336= 71,736 / 28.5 = 2517 rpm
Same thing with a 3.91 ratio:
50 X 3.91 X 336 = 65,688 / 28.5" = 2304 rpm
Same thing with a 3.73 ratio:
50 X 3.73 X 336 = 62,664 / 28.5 = 2199 rpm
This formula takes into account a transmission that is one to one ratio in high gear.
So my thought is that it is not as bad as I thought it would be. I actually thought it would be over 3000 RPM at 50 mph. It is however a lot of engine wear over time and a lot of gasoline. Austin wants his truck original so it is what it is. Shouldn't be slipping the clutch on take off!
Old Oct 21, 2016 | 09:02 AM
Harrier's Avatar
Harrier
It's handy to see.
There are tools out there that do the math for you.
Here is one: Tire Size, RPM, Speed, and Differential Ratio Calculator
akford1
19
Nov 21, 2012 07:24 AM
TucsonTripleB
Sep 19, 2010 03:11 PM
Whiskey Bent
Mar 15, 2009 12:07 AM
77bigblock
Nov 7, 2006 07:55 PM
51dueller
Feb 26, 2004 11:54 PM
