Clutch Problems
Old Jan 2, 2002 | 08:48 PM
tonyboy52's Avatar
tonyboy52
Clutch Problems
Need help with hydralic clutch. Pedal went to floor . do't come up. Small leak at slave clylinder. Should I just bleed it or replace cylinder and throw out bearing.
Old Jan 2, 2002 | 11:33 PM
PAUL_2's Avatar
PAUL_2
Clutch Problems
It sounds like the slave valve is dead , It more than likely needs replacing . What model , yr , mileage etc ? If its an internal slave valve then you will have to pull the transmission and or transfer case if its 4WD . At that point you may as well put a new clutch disc , pressure plate , pilot bearing & replace the rear main seal seal if its leaking . The new slave valve will come with the throw out bearing already installed .
Old Jan 3, 2002 | 04:51 AM
lanero's Avatar
lanero
Clutch Problems
