Good morning to all Ford and Lincoln owners,
I Write from Italy, where to have a US truck or suv is Not conventional and sometime complicated,
Last week a bad man have in The night brocken my front passenger Side window glass.
From Usa is hard to reach it, l'm searching in some Europe damaged cars depots,
My question is: did Navigator or Expedition 2nd gen.(2003-2006) front window glass Fit on 1st gen.(1997-2002) model?
I have a 1998 model.
Thanks to all
Giuseppe
21410 is the Location Code, so it will be on every 4 door Ford vehicle. You may confirm this by checking on a Ford Mondeo parts catalog.
Which window was broken? Also, do you have standard GREEN tint. or the GRAY privacy tint? My 1997 Expedition XLT came with gray tint.
Expeditions are very common here and I can pull one at a salvage yard for you. The window is about $15-$20 USD, plus the cost of shipping.
With correct packing, the dimensions are approximately 30 inches long by 36 inches wide by 3 inches tall. it will weigh less than 10 pounds (4.5 kg).
Thank you very very much for your interest on matter, my is green tint. If you can organize shipment (better insured for brocken damaged) to Italy, I can buy immediatly, I need also dash radio bezel frame tan (with 2wd/a4wd/4wdl/4w2l switch) and center consol under, only the up part with holz frame and black rubber mat and 2 cup holder. If are decent also a set of tan carpets so they save window glass from damages.
I wait for you before confirm any order.thank you again, my mail is: info@americanspirit.eu than you and greets from Italy
