Sponsored by: Auxito
which engine?
Old Aug 22, 2003 | 07:24 PM
Dave the Brewer's Avatar
Dave the Brewer
which engine?
Hi all,
I've been very happy with my Aerostar 4.0 XLT van but after 200,000 miles I'm looking to replace it. I'm thinking about an E150 Club Wagon XLT Chateau, fairly loaded, as I expect to take some long motor trips over the next few years.
Question is, which engine? I'm inclined to rule out the V6 as underpowered for this van, especially when running the high output front and rear A/C. Would the smaller V8 be adequate, or should I go for the 5.4?
On a related note, the only towing I expect to do would be a lightweight motorcycle trailer with one bike. Is the standard equipment sufficient, or should I go for the heavy duty deluxe trailer towing package?
Thanks for your advice on this--
Dave
Old Aug 22, 2003 | 10:17 PM
LxMan1's Avatar
LxMan1
which engine?
I would get the 5.4L, the gas mileage is about the same and the added torque is nice. The class III towing package is nice, heavy duty battery, Reese style hitch, prewired for trailer lights and brakes and heavy duty shocks.
I'm glad that I got these on mine. Plenty of power and no hassle trailer light/brake wiring.
Jimmy
Old Aug 27, 2003 | 07:16 PM
Hawks's Avatar
Hawks
which engine?
I would recommend the 5.4V8 if you live in a mountainous or hilly area, hauling load, or towing. 4.6LV8 should be fine for interstate commuting and doing limited towing.
Old Aug 27, 2003 | 09:00 PM
jimh1's Avatar
jimh1
which engine?
I wouldn't even consider anything but the 5.4L. The 4.6L is probably OK on the F150, but the E150 will weigh at least 1000 pounds more than the truck. (even the 4X4) I have a 2000 conversion van that weighs in at 6300 lbs w/full tank and family. The base curb weight for the F150 4X4 is somewhere around 5000lbs. Options will add some, but not a thousand pounds. Also remember that both engines make less HP and torque in the vans. I'm told it is mostly due to exhaust restriction. Having said that, the van is an excellent travel vehicle.
Old Aug 28, 2003 | 09:16 AM
ggarrahan's Avatar
ggarrahan
which engine?
I agree, get the 5.4L. I have one in my '03 F150, and am very pleased with the power. The 4.6L just does not have enough torque. A test drive will fool you, the 4.6 will seem fine, but put in a load, pull a trailer, or drive in hilly country, and you'll wish you had the 5.4. Look at it this way, mileage is about the same, and if you don't want the power, just push less on the loud pedal!
Old Aug 28, 2003 | 10:19 AM
MrBSS's Avatar
MrBSS
which engine?
I am going to give a contrary opinion. The 4.6 will be just fine for your useage and it will get significantly better mileage. I think it'll also save you close to $1000 initially (Not sure on current van prices). If you drive in mountains much, or were used to driving a Cobra, I might agree with the 5.4.
I would, however, get the towing package because it's relatively cheap and will give you some extra margin for towing and longevity; also for when you're running all that AC.
Brian
Old Aug 28, 2003 | 01:22 PM
Lectrocuted's Avatar
Lectrocuted
which engine?
5.4. Vans are heavy and push quite a bit of air (what doesn't though).
Old Aug 28, 2003 | 06:40 PM
jimh1's Avatar
jimh1
which engine?
All I know is that the big vans are heavy-considerably more than an F150 and both of the engines make less HP and torque in the van. I own a van w/the 5.4L and even my wife thinks it is a little sluggish with the chip turned off.
rlentz
39
Dec 24, 2010 08:17 AM
misteramx
16
Jan 10, 2007 01:08 PM
dave11o11
All Things Towing
Oct 23, 2003 04:47 PM
Seleya
1997 - 2003 F150
Jan 18, 2002 06:11 PM
kmlford
Jan 25, 2001 03:36 AM
