Differences between E250 and E350
Old Oct 24, 2016 | 10:45 AM
Teutonics's Avatar
Teutonics
Semi-float axles have been known to fail under use with heavier weight vehicles (e.g. camper conversion), use of wheel spacers (creating more leverage on the axle), or both. I have also seen some reports of failure due to water intrusion/rusting/corrosion of the axle race surface (part of the axle, not separate/replaceable) on the SF axles, more so than a full float axle.
Pros - more reliable under extreme duty
Cons - more $$$
Old Oct 24, 2016 | 05:02 PM
fordman75's Avatar
fordman75
Cons - more $$$
Yep you are correct.
The semi-floaters axle shafts are usually the inner race for the axle bearings. When the bearings go bad your axle can become junk. Plus changing axle bearings on them can be a royal P.I.T.A.!!!
And on the full floating diff you can pull the axles with the van's rear tires still on it and sitting on the ground!! And you can pull the axles without pulling the diff cover. You can't do that on a semi-floater!
The full floater weighs more, has more parts to service ( 4 bearings instead of 2, separate hubs, etc. ) so it will cost more. But it is much stronger. And if you do any heavy towing/hauling it's the smart choice.
Old Oct 25, 2016 | 07:53 AM
Toppa's Avatar
Toppa
ok... good to know. i gonna check what i got...
are there any drawings about the difference? not necessary, just interested never do heavy towing
Old Dec 5, 2016 | 06:28 PM
Sam I Am's Avatar
Sam I Am
Originally Posted by fordman75
It took me some searching but I found this 2000.5 disc brake D60 FF with 4.10 gears and LS. It should be plenty strong for my van.
If you don't mind me asking, what did you pay for that D60?
Old Dec 5, 2016 | 08:13 PM
fordman75's Avatar
fordman75
I paid $350 for it.
Boondockdad
31
May 19, 2016 09:22 AM
leardvr
May 4, 2013 10:29 AM
95e150CW
Jun 24, 2012 09:56 AM
don1
All Things Towing
May 14, 2007 10:58 AM
steven1955
Apr 11, 2005 12:40 PM
