Draining a C6 without a drain plug
Old Oct 11, 2016 | 04:58 PM
CelticOne's Avatar
CelticOne
Regular User
I know the usual method is to drop the pan and drain it that way. I plan to add this plug while I have it out:
https://www.amazon.ca/gp/product/B00...K6Y9EEQB&psc=1
What if I drill a small hole in the pan in the location the plug is going, while still full and on the truck, and let it drain through that hole? Once empty I pull and clean the pan, install the plug, change the filter, and reinstall pan.
Would this work or am I just looking for trouble (as my mother would say)?
Old Oct 11, 2016 | 05:21 PM
TheMonson's Avatar
TheMonson
I've thought about that too but chickened out for fear of running the drill in too far and/or getting ATF everywhere, you know more so than usual.
Old Oct 11, 2016 | 05:27 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Drawback would be oil running down the drill and killing it. If you were quick enough though, you might be able to use a small bit with a stop collar on it. Find a short piece of copper (or whatever) tubing, get a drill bit that fits snugly into the ID of the tubing, then trim length so only 1/4" or so of the bit sticks out past the tubing. Don't forget rags....
Old Oct 11, 2016 | 05:37 PM
dlburch's Avatar
dlburch
not worth the risk in my opinion, and you'll probably make a bigger mess than you would just removing the pan the old fashioned way...I use a rubbermaid 30 gallon trash can lid...no mess on the floor.
Old Oct 11, 2016 | 06:31 PM
good to doo's Avatar
good to doo
I say go for it. I did the same on a 9inch rear end. Go slowly and any particles will get pushed out by the oil flow.
Old Oct 12, 2016 | 07:38 AM
CelticOne's Avatar
CelticOne
Regular User
Where is the best/safest location for the drain? I've seen pictures of ones installed on the rear side near the bottom as well as the rear bottom of the pan.
Drilling the side of the pan would mean less of a mess dripping onto the drill and my arm, should I decide to go that way. Thoughts?
Old Oct 12, 2016 | 08:34 AM
DeepRoots's Avatar
DeepRoots
Why not just pull the modulator, let most of the oil drain and then drop the pan in the conventional way?
Old Oct 12, 2016 | 11:52 AM
kwe45919's Avatar
kwe45919
Use a hand drill.....no electrical drills. Center Punch it and drill it where ya want it. Use something to catch the oil. Done in 10 min.
Old Oct 12, 2016 | 12:33 PM
CelticOne's Avatar
CelticOne
Regular User
Thanks for the suggestion. I haven't seen this approach in my research. Have you (or others) done this?
Old Oct 12, 2016 | 03:09 PM
DeepRoots's Avatar
DeepRoots
Yeah. It doesn't drop ALL of it, but it makes it a ton easier to drop the pan.
I just remove the back bolts of the pan and work my way forward. by the time you get to the front there is only a quart or two in the pan and it's easy enough to deal with.
I would be careful with the punch, hate to warp a pan, the stock ones are normally pretty rough by the time you get to them :P
I've changed fluid in a c6 probably 100 times.
On another note, a chrome pan with a drain plug is only like $30..... just an fyi.
https://www.summitracing.com/search/...rder=Ascending
Old Oct 12, 2016 | 06:00 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Whatever the lowest point on your pan is, how it sits right now.
Old Oct 13, 2016 | 02:13 AM
Ozzie H.'s Avatar
Ozzie H.
If you use the plug as designed it won't drain all the oil. Also be sure to read the user feed backs regarding leaks. I used a 1/8" NPT slotted bung and brazed it in at the lowest point on the pan. It drains all the fluid and does not leak.
Old Oct 13, 2016 | 10:56 AM
HoustonDave's Avatar
HoustonDave
I'm the contrarian, I guess - I would drop the pan, install the drain plug, and use it the next time. All the shavings should rinse out, true - but a) I want to make sure the inside of the holes is deburred and b)with my luck, I'd be "that guy" for whom that one big shaving would stick in the pan, and I would find out about it about the time it jacked up my transmission. Plus I would want to change out the filter at least once, and it's really hard to do that through the drain plug. My $.02 - drop the pan and do it right. As my father used to say "You don't have time enough to do it wrong the first time."
Old Oct 13, 2016 | 11:29 AM
CelticOne's Avatar
CelticOne
Regular User
Thanks for the input, Dave. I will be taking the pan off anyways to replace the screen. Was just looking for a cleaner way to do it. I'm leaning towards your suggestion at this point. With perhaps pulling the modulator off first to drain the top end.
My understanding is that there are +/- 3 quarts in the pan. Is the rest (+/- 10 quarts) all in the TC?
Old Oct 13, 2016 | 03:26 PM
FMJ.'s Avatar
FMJ.
I wouldn't drill into the oil pan unless I knew with 100% certainty, that there would be no clearance issues once the drain plug is fitted.
Drilling blindly into the pan sounds like something Left Eye Blind racing would do. (The shades cover the blind eye !!)
Rather drain the TC, remove the modulator (good idea that ! ), then drain the cooler (if pipes are higher than the pan), then the pan.
Once the pan is off you can double check exactly where to fit the plug.
As HD says, rather do it right.
Is that B&M plug magnetic ?
If not, better to get a magnetic one, or, place a magnet outside the pan next to the plug.
Food for thought : an ally finned pan with a plug already fitted.
