Well I'm down to the final parts install on the new engine. As in previous threads I gutted the emissions crap. So I'm left with vacuum lines that go everywhere. The power break line I will hook to the back of manifold. PVC goes to the air cleaner. Dissy vacuum advance to the carb. bottom front. Transmission to the manifold back. There is a cruise control line I'll just find a open port. Can you review and let me know if I'm wrong. THX David
P.S. I'm using the old carb spacer just blocking off the EGR in the back. Question is there was no gasket between the spacer and manifold is this OK. There is a 1/4" one between the carb. and spacer. Can I reuse or get new not to bad of shape. THX David
