Need Help! Fast!
Need Help! Fast!
On my way to work last night i blew a radiator line.. This morning i got everything to fix it and it took 2 and a half gallons of anti freeze to fill back up.. my temp gauge didnt go up past the A on the Normal and shut it off.. but on my way home feels like extreme loss of power and when you manually shift when you finally get to a high rpm it starts missing and trys to fall on its face... think its my heads? or poss. sucked anti freeze in threw my throttle body or maybe in my distrubitor cap? I know it soaked the whole motor.. need to fig out soon my only vehicle to get me to work
I would check all the spark plug wires and make sure you didn't knock one lose when your were doing your repairs. Check all other electrical connections. Check the connectors that go to your distributor and make sure no coolant got in there.
Hopefully this isn't the case, but if it overheated badly enough when the hose blew you could have blown a head gasket. I would start with checking the simple things first though.
Tienfan789
20
02-05-2017 12:12 PM
NightCrawler
1983 - 2012 Ranger & B-Series
60
05-01-2008 06:57 PM
Cody D
01-23-2008 11:07 PM
87 F-150 I6
08-29-2007 03:47 PM
