Need Help! Fast!
Old Jan 19, 2013 | 11:42 PM
K3NN3DY's Avatar
K3NN3DY
Need Help! Fast!
On my way to work last night i blew a radiator line.. This morning i got everything to fix it and it took 2 and a half gallons of anti freeze to fill back up.. my temp gauge didnt go up past the A on the Normal and shut it off.. but on my way home feels like extreme loss of power and when you manually shift when you finally get to a high rpm it starts missing and trys to fall on its face... think its my heads? or poss. sucked anti freeze in threw my throttle body or maybe in my distrubitor cap? I know it soaked the whole motor.. need to fig out soon my only vehicle to get me to work
Old Jan 20, 2013 | 12:23 AM
88n94's Avatar
88n94
I would start by looking at and probably replacing the air filter. Maybe check under the distributor cap. Is there any coolant standing by your spark plugs? Which engine do you have? I assume 1992 F-150?
Old Jan 20, 2013 | 12:28 AM
K3NN3DY's Avatar
K3NN3DY
the blocks out of a 89 gt car with gt40p heads everything else is reg. 5.0 and i took my filters off and ran it and still doing the same.. i fig. it may have got on em and gooked em up.. but taking them off didnt help
Old Jan 20, 2013 | 12:35 AM
geoffunkel's Avatar
geoffunkel
I would check all the spark plug wires and make sure you didn't knock one lose when your were doing your repairs. Check all other electrical connections. Check the connectors that go to your distributor and make sure no coolant got in there.
Hopefully this isn't the case, but if it overheated badly enough when the hose blew you could have blown a head gasket. I would start with checking the simple things first though.
Old Jan 20, 2013 | 12:39 AM
K3NN3DY's Avatar
K3NN3DY
I checked the oil when i got it home.. it looked good but i app the help.. Im gonna set here at work sick till i can get it in the garage and go threw everything.. hope its something simple
Tienfan789
20
Feb 5, 2017 12:12 PM
NightCrawler
1983 - 2012 Ranger & B-Series
60
May 1, 2008 06:57 PM
Cody D
Jan 23, 2008 11:07 PM
87 F-150 I6
Aug 29, 2007 03:47 PM
FlyinRyan07
Dec 15, 2004 04:18 PM
