250 or 350
Old Oct 7, 2016 | 10:29 AM
slipry14's Avatar
slipry14
250 or 350
What is everyone's opinion on this? On my last Super Duty I went with the 350 just because the price difference was negligible. I do not necessarily need the extra capacity because I don't haul anything extremely heavy. Is the ride that much better on the 250 vs 350?
Old Oct 7, 2016 | 10:37 AM
Kampn's Avatar
Kampn
I tow, so my bias would be for the 350, I would think the ride quality will vary with the spring package, I'm sure others can say more about this.. I would also check the state that you live in and see if there are higher registration taxes for the GVWR.
Old Oct 7, 2016 | 11:19 AM
The Ace of Spades's Avatar
The Ace of Spades
F350 for me, I would never consider an F250, but I tow heavy. Even if I didn't tow heavy, I would still go 1 ton. You just never know what might happen that might cause you to need that higher capacity, I'd rather have it than not have it.
Old Oct 7, 2016 | 11:29 AM
Rasalas's Avatar
Rasalas
Current truck is an F250. Very rarely tow heavy, but it happens. Often carry a 3500lb camper and will continue with the new F350. Added air ride to the F250 for the additional rear support and it handles the camper OK. Should be better on the F350 though, we'll see someday.
Old Oct 7, 2016 | 02:10 PM
archerseven's Avatar
archerseven
Loving the torqshift-g in my 250. I'm also of the type that is normally in half ton territory and only on occasion do I need the extra truck.
Old Oct 8, 2016 | 01:23 AM
Robmiezer's Avatar
Robmiezer
After testing both, they road the same on a street and freeway. The 250 will be a bit smoother, but is rated lower tows less. If you never plan to tow more than its max. Then the 250 is the way to go. If you plan on hauling a camper, big 5th wheel, or toy hauler than the 350. But, it is your truck. If you want more advice read through the posts. It has been asked numerous times
Old Oct 8, 2016 | 09:26 AM
69cj's Avatar
69cj
As stated many times before "Better to have too much truck than not enough" It only takes once to pay for itself.
cnegley3rd
Dec 11, 2017 01:49 PM
sawtooth
6.7L Power Stroke Diesel
Nov 16, 2017 05:55 PM
Sf jakey
Oct 23, 2017 11:25 PM
ChrisDGall
Sep 29, 2016 04:28 AM
Mayberry
Aug 8, 2016 06:34 AM
