Where do I go now? EOT vs ECT
Old Oct 5, 2016 | 05:21 PM
2006powerstroke90's Avatar
2006powerstroke90
Okay, as you guys know I just replaced my oil cooler and did an EGR delete but today on my way home I saw ECT 190 EOT 210 so I'm getting a 20* delta now.
Since my egr is deleted do I not worry?
The day before I did the oil cooler I did a complete coolant flush and back flushed the oil cooler, the day after I did the oil cooler I installed a coolant filter.
Do I tear it all back apart and do the oil cooler again? Any input would be appreciated.
Old Oct 5, 2016 | 05:45 PM
TooManyToys.'s Avatar
TooManyToys.
Did you back flush or get the radiator cleaned before bolting it all back up?
Old Oct 5, 2016 | 05:48 PM
2006powerstroke90
Radiator was removed and brought to a local rad shop and they flushed it and cleaned it, $110 later
Old Oct 5, 2016 | 05:57 PM
TooManyToys.
Damn! There must have still been materials in the block assuming they did a good job.
Sensors OK?
While you don't have an Egr cooler to worry about, it's not doing its primary job of cooling oil. The salvage operation is to drain, remove water pump, and back flush through the oil cooler output port to try to blow out any debris that clogged the new cooler. If that doesn't work, it's another cooler.
Old Oct 5, 2016 | 05:59 PM
2006powerstroke90
I would imagine they do a good job my shop uses them without issue.
Is there a way to test the sensors? This morning I saw a 5.5* difference between them after sitting for 1.5 days
Old Oct 5, 2016 | 06:07 PM
TooManyToys.
Sounds like the shop is good then.
That's a good clue, the 5 degree differential. Hopefully it's just a sensor issue. Coming from a world of more specialized sensors then these, you can both a zero shift and a gain (high value) shift. I would check to see if both the oil and coolant sensors on your year truck are the same part number. If so you could flip them in positions, or just replace the oil sensor as that's the one elevated from normal. I'd first check that the connections are good after the rework.
Old Oct 5, 2016 | 06:09 PM
2006powerstroke90
https://m.summitracing.com/parts/smp-tx61
I found these at my local parts warehouse both show the same part # for EOT and ECT sensors
Only difference I see is the OEM ones have o rings and these have teflon tape, for $13 I might try that first if not I'll be ordered another oil cooler.
Old Oct 5, 2016 | 06:17 PM
TooManyToys.
I know from direct information that Ford keeps a tighter control of its sensors manufacturing spec, including the Motorcraft aftermarket. Considering the task your trying to avoid, I think I'd be going with the Motorcraft just to be sure.
Old Oct 5, 2016 | 06:22 PM
2006powerstroke90
They also have OE parts as well but they are about $30 a sensor. From what I have been vigorously reading the proper way to test the deltas is 65MPH on a flat road for 20 minutes or so?
I should probably note living in CT and living in the north end of CT it's very hilly and I usually cruise around 85 mph and I noticed the temps going up a steep grade, I know I'm trying to make the numbers seem logical in my mind but I really don't want to do another oil cooler again...lol
Old Oct 5, 2016 | 06:29 PM
navistarnut's Avatar
navistarnut
It's possible your 5.5* spread is more than that as temps rise....i.e the sensor is more out of whack at higher temps, however going 85 and hilly is not the best way to judge things....you really should do the Ford test.
Old Oct 5, 2016 | 07:12 PM
TooManyToys.
60mph flat road, 15 minutes will do if the truck had been driving 30 minutes.
The problem is the specfic heat differences between coolant and oil, and as you add heat into the oil due to higher engine workloads it can't get absorbed by the coolant fast enough, so the oil to coolant temp differential will rise.
Mike, the only "Ford" test is the acceleration one.
Old Oct 5, 2016 | 07:49 PM
navistarnut
Hmmm, thought I saw a flow chart somewhere for Ford techs for the flat surface driving.......what is the acceleration one you refer to Jack?
Old Oct 5, 2016 | 08:41 PM
TooManyToys.
This is the only official test I've ever seen from Ford.
This is where the flat road test began, friggin guy ...
EOT vs. ECT after oil cooler replacement - Page 3 - Diesel Forum - TheDieselStop.com
Or maybe I'm on drugs. But how I remember it.
Old Oct 5, 2016 | 08:52 PM
BLADE35's Avatar
BLADE35
Crap tyler looks like a bad sensor
they should be within 1-2*
your at 5.5* at cold soak and it might get worse as it heats up meaning not Linear
Old Oct 5, 2016 | 08:57 PM
TooManyToys.
Hopefully, not the reason for swapping oil coolers in the first place.
