Sponsored by: Auxito
4R70W shuddering?
Old Dec 16, 2023 | 09:29 PM
  #76
SCHMIDTY26's Avatar
SCHMIDTY26
2nd Gear
Thank you
Old Dec 16, 2023 | 09:37 PM
  #77
SCHMIDTY26's Avatar
SCHMIDTY26
2nd Gear
Originally Posted by Bluegrass 7
Misfires only in OD at light throttle:
In OD the EGR is called to open allowing exhaust gas to flow into the intake tract, by design.
The purpose is to lower combustion chamber temperatures.
This action advances the ignition timing and reduces fuel injection amounts.
The results of this action is a very LEAN condition.
The Lean condition needs an ignition system in good condition due to the higher voltages required to fire the Lean mixture condition.
If any cylinder falls short on voltage, misfire will result under these specific conditions.
When the EGR closes from down shifting the EGR closes and conditions return back to lower voltages required to fire the standard mixture ratios.
Best way to find an offending coil is to look at stored data under mode 6, test 53.
This stored data is the misfire counts for each cylinder.
If any cylinder has high counts it likely is a cause of misfire and will not set a code.
The reason is the condition comes and goes with the driving condition so is actually cancelled as a possible code set due to it not being a 'hard' fault.
Bottom line is, do the testing before replacing parts.
Good luck.
Bluegrass thank you for all of the details in this thread, I know I have dug this one up from the dead, but it was a huge help. I was struggling finding the culprit of a bad shudder (going over rumble strips feeling) in my mustang with 4.6 and 4r70w trans. The shudder Only occurred from 45 to 60 in over drive. I had just finished up rebuilding the trans so I assumed the worst with it. But as stated it ended up being the coil packs and a coincidence that they failed at that time. Thank you again!
hendedo
1997 - 2003 F150
Jul 12, 2011 08:31 AM
tomsen5
Sep 7, 2007 07:58 AM
Randy8216
1997 - 2003 F150
Jan 29, 2007 05:08 PM
Al_V
1997 - 2003 F150
Sep 20, 2005 09:18 AM
jlarr
Jun 28, 2005 08:35 PM
