351W vs big block
A Built 351W vs. a Stock or Mildly built 460, sure the 351W could beat it.
The trick is you will have to build the heck out of the 351W, push it harder and to a higher RPM to get the same results as the 460.
I have nothing against the 351W, it is actually my favorite small block, but there is truth in the statement "There is no replacement for displacement". For these old trucks, torque is king.
Just a small question, how many people do you know which personally daily drive a gasoline vehicle with over 500HP, without computer controls? How much work(adjustments) do they do on a regular basis? Are they running vacuum brakes? How does it idle etc etc
500HP can be done but having it for a daily driver, no towing good power....
If you have the Windsor and overdrive transmission it would be a fun build to watch on FTE. No need to go through the roof with goodies but I will sit behind my keyboard once a week and cheer you on if you want to turbocharge a big or small block in a dent.
Good luck on your search for a truck
A 351W will have to breathe at 5000+ RPM to make 400 HP.
To make over 400hp in a 351 and get 150+k through it with minimal maintenance you need to start with a excellent block or aftermarket block.
You throw a 408 kit into a block which isn't line honed mains and cam, oil mods etc it won't last. I know I've built one. It's sitting under my deck and I'm building a 460 because it will make the power I want for a very long time.
I love the 351W. I made it into a 427 great crazy power. But the cylinder walls were so thin it would overheat in traffic. The juice wasn't worth the squeeze.
Now keep the stroke Stockish with forged internals and a 50mm turbo and good tune using a mustang computer you've got it made. That will make lots of power with the right heads and cam.
But build what you want. Take lots and lots of pictures I would love to see either get built.
A correctly built 351w would out perform a stock 460, but a built 460 would/could run circles around a built 351w.
"The 460 will pass anything on the highway... except a gas station".
If you don't care about fuel economy, go big. Go 460. It's an absolute pig, but it makes tons of power.
A fully modified 351W wouldn't exactly be fuel efficient, but it wouldn't suck as much fuel as a modded 460 either.
I think I have run just about every engine combo in these trucks I can think of. They were all within a 1 or 2 to the gallon with my mildly built 429 giving a steady 14-15 mpg , if I was super nice to my 302 it would give 16 . The worst was my 300 six. My 351m's and 1 Cleveland would all be in the 13 14 range. And before someone calls me on it, I use Canadian gallons which are larger than the US gallon.
Big blocks like the 429 and 460 don't work near as hard as a small block to do the same thing.
Now my 460 in my newest supercab got 15 hwy the whole 800+ mile trip from Kansas to Wisconsin. In town mileage sucks though. Doesn't help the PO never really serviced the motor and it's out of adjustment in every way possible.
The last two statements you made says it all. First off, good power in a daily driver is a 350hp mild 351......OR a stock 460. Both have streetable power and would be good for daily driving as a "tool truck" or lumber yard truck and do just fine in a Dent F100 or F150.....both motors are reasonable to build and would give light towing capacity.
Now....if it's really about max HP....no doubt a 460 will fit this bill better than the 351 no matter the truck
..... if its really going to be a solid work horse, run into ground, and you are looking at finding an F250, then your 460 would be a great choice.
It really depends on if you want a daily driver or a performance driver and what size Dent you plan on putting it in....
I'd use it, especially if it was free. If it needs some work, then do it.
My father has a 408 powered '79 F350 long-bed. It makes about 500hp and 522ftlb, and moves along really well. No issues cruising, going uphill with a load, or beating the local hotted up sedans and coupes in the traffic light drag races!
Before he did that to it, it was a regular mildly built 351... and even then it was great to drive. In a lighter vehicle that mild 351 would have been a weapon. If I recall it was about .030" over, stock crank and rods, mildly ported heads, stock dual plane intake and Thermoquad, and a fairly tame camshaft - something akin to an 'RV / Torque' grind from TRW, Summit or Elgin.
Seeing as you already have the 351 and trans, I would use it.
