Brake component name
Old Oct 3, 2016 | 07:45 PM
kiohio1985's Avatar
kiohio1985
I've looked all over and can't figure out what you call it.
I'm pretty sure it adjusts your brake bias more to the rear when you have a load on.
Since this is on the F350 4x4 Dump that's my best guess.
I want to go thru the brake system, new lines hoses etc.
So I need to know what this is called in case I break it and need to replace it.
Thank you,
KO
Old Oct 4, 2016 | 07:15 AM
reamer's Avatar
reamer
Try "rear brake proportion valve for a F-350"
Old Oct 4, 2016 | 10:13 AM
kiohio1985's Avatar
kiohio1985
The 85 in my sig at approx 6500 empty probably wouldn't really need it would it?
Thank you
KO
Old Oct 4, 2016 | 10:41 AM
WhatsAChevy?'s Avatar
WhatsAChevy?
Thank you
KO
Not sure what you mean by "probably really wouldn't need it" ??
Old Oct 4, 2016 | 03:31 PM
kiohio1985's Avatar
kiohio1985
Just from what I've read it's for dialing back the rear brake bias when empty.
It weighs quite a bit empty, so i just wonder how much more it can give to the rear, if any.
KO
Old Oct 5, 2016 | 04:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I'm pretty sure it adjusts your brake bias more to the rear when you have a load on. Since this is on the 1985 F350 4x4 Dump that's my best guess.
Brake Load Sensor Proportioning Valve Assy., basic Ford part number: 2B547
1985/89 F350 4WD: There are FOUR different types, as it depends on the engine size and the GVWR
Old Oct 6, 2016 | 07:38 AM
kiohio1985's Avatar
kiohio1985
Thank you
1960fordf350
May 29, 2019 12:50 AM
aussiecowboy
Jun 24, 2013 08:13 PM
Milwaukee1979F150
Mar 13, 2009 12:02 PM
dionysius
May 6, 2007 08:11 PM
PELLET
Dec 15, 2006 03:31 PM
