Sponsored by: Auxito
2002 f150 supercrew longbed
Old Oct 9, 2016 | 09:25 PM
mybloodisblue's Avatar
mybloodisblue
Well i got a beautiful weekend and i got more work done on my truck
Old Oct 10, 2016 | 09:56 AM
blupupher's Avatar
blupupher
That just does not look right.
Not in a bad way, just that long bed on the Supercrew is something my mind can't process. Once painted the same color it will probably flow better though.
Still an ambitious project that will be one of a kind.
That front end seems to be sitting high compared to the rear. I am guessing the torsion bars are cranked on it?
Are you going to have to do a custom driveshaft? Maybe a 2wd long bed supercab driveshaft would work?
edit: never mind on the second half of my post. I forgot your doing a SFA so the ride height will not matter and a complete drivetrain swap with new rear axle will mean a custom driveshaft.
Old Oct 10, 2016 | 10:16 AM
mybloodisblue
The crew had lift blocks in the rear and torsion bars cranked up with 35s on it the rear is stock and i just didn't bother with it because I'm doing all the other stuff
Old Oct 10, 2016 | 10:24 AM
mybloodisblue
We have a place called power drive here they do awesome stuff with drive shafts
Ive found its way cheaper to have one shortened i got a rear drive shafts out of a 06 f350 crewcab long bed dually 2wd which is waay to long so once i get my engine swap and axles done ill get my measerements for drive shafts then get them made ....shorten and balance usually runs about 80 bucks ...but i always have them do new joints another 80... this will be my first one with carrier bearing so im thinking another 80ish so im thinking 250ish
The front is the one that bothers me
Old Oct 10, 2016 | 10:40 AM
blupupher's Avatar
blupupher
Do the long beds on the 10th gen have a carrier bearing or are you going to have to fab a mount for that too (not that it really matters with everything else your fab'ing)?
The front one, well, once you get it all together and measured, you may be able to find something that fits, or close enough to get modified vs all new. The good thing is you can drive it with just the rear, so the front shaft will not be a hold up in driving it.
Old Oct 10, 2016 | 10:51 AM
mybloodisblue
The 02 longbed extended cab had a carrier the 06 f350 had one and my buddys 2012 has one. ...i talked to the drive shaft place awhile back they said there is a law now that one piece drive shaft is not allowed to be longer then 70 inches u joint to u joint
Old Oct 10, 2016 | 08:08 PM
guyina4x4's Avatar
guyina4x4
[QUOTE=mybloodisblue;16633923]Well i got a beautiful weekend and i got more work done on my truck
I like it
Old Oct 13, 2016 | 02:46 AM
Keanu's Avatar
Keanu
Thank you for showing! I always wondered what this would look like, but I thought more of using the 6 ft bed. You could be hauling goosenecks with this. Although this looks amazing, I'm kind of glad my stock truck fits in the garage.
Old Oct 13, 2016 | 07:13 AM
mybloodisblue
Its 23 feet tip of bumper to tip of bumper so it will fit in some garages my uncles garage is 25 x 25 .....but mine is 22 x 18 so not even close .......and yes a enclosed goose neck trailer for my race car ..is the plan and i could of got a 4x4 f250 or f350 long bed crew but i couldnt see stuffing a cummins in a truck that cost 4 to 10k with a bad engine .. i have kids so i had to have a crew and have a lot of stuff so i had to have a long bed so i decided to build this ... i think a 6 foot box would look awesome as well though
Old Oct 22, 2016 | 11:55 PM
tdl0's Avatar
tdl0
Very cool. When I was still considering buying a new truck I was surprised to see that they didn't offer this configuration. I guess it makes sense when you think of the sheer length of the thing. I think it'll definitely turn heads when finished.
Old Dec 5, 2016 | 01:16 AM
Keanu's Avatar
Keanu
Is this a 4x4?
Old Dec 5, 2016 | 05:20 AM
blupupher's Avatar
blupupher
Originally Posted by Keanu
Is this a 4x4?
Originally Posted by mybloodisblue
My long bed supercrew is Getting Dana 60 in the front and Dana 70 in the rear ...
sounds like a 4x4 to me
Old Mar 6, 2017 | 09:00 AM
  #28
mybloodisblue
So ive had alot of life things going so i havent touched my truck for several months ..but i should be back on it in the next month or 2.. but as of this week i have started on my wifes truck which i will start another thread for
Old Mar 6, 2017 | 09:29 AM
  #29
mybloodisblue
2007 f150 supercab 4x4 32v 5.4 swap
is the thread for the wifes truck for anyone following this thread and is interested in the other one as well
Old Mar 7, 2017 | 09:45 AM
  #30
rjent's Avatar
rjent
Personally, I would like to see the original build, but the images are broken.
Yes, by all means show your wifes truck. There should be a lot of interest!
