Brake hydraulics question
Old Oct 2, 2016 | 09:33 AM
ctubutis's Avatar
ctubutis
Stripped, how do you mean? The corners are so rounded off you can't get a hold of the fitting? Or the threads are somehow so mangled the thing won't come out (which I wouldn't understand, stripped threads usually result from overtightening but I've never seen one that can't be removed when that happens)?
Old Oct 2, 2016 | 09:47 AM
Sykesville's Avatar
Sykesville
Yes, the corners are rounded off. Should I use vise grips? Drill a hole through the fitting and put a screw through it to get it to twist?
Old Oct 2, 2016 | 09:51 AM
matthewq4b's Avatar
matthewq4b
Just use the Visegrips first before doing anything else. But as I said you need to have a good pair with sharp teeth.
Old Oct 2, 2016 | 09:55 AM
ctubutis's Avatar
ctubutis
I like the Vice-grips idea and is probably something I would try if I ran into something like that. Failing that, there are specialized extractor tools for this kind of job but I'd try the vice-grips first.
Old Oct 2, 2016 | 10:09 AM
Sykesville's Avatar
Sykesville
The thing was seriously rounded, but the vise grips got it! Used the teeth in closer to the handle. Thanks gentlemen, I am eternally grateful. Be back soon with some other question, I'm sure. Cheers.
dwstenersen
Jan 9, 2017 01:46 PM
1968F100ShortBed
Sep 12, 2010 10:26 AM
Screamin T/A
Dec 15, 2006 03:21 PM
dubbz
1983 - 2012 Ranger & B-Series
Dec 22, 2005 11:25 PM
cmoore
Jan 17, 2003 02:18 PM
