Post your gauge set up!
How do you measure the EGT? On my truck the PO told me that its x10. Its usually at 20 (x10). But yours only goes up to 15 it seems. Or do you have a different set up that it will never go that high?
I have a 3" straight pipe. Would love to know how I can keep EFT's down, they go up fairly quickly if im hitting about 7lbs of turbo, empty F350 dually longed, on a slight incline. If im driving on flat grounds, 20 EGT = 200 degrees. 35 more going up hill.
Where is the probe?
12 x 100=1200*
you don't want to run these IDI's past 1300, the cast and the aluminum cant take it.
don't drive the truck much right now, because I got things to do to it. and shes not ready, im also doing another truck too lol
don't need a trans temp with a ZF
I could use an oil temp....
Remember that the temps you see depend on where your sensor is. If it's pre-turbo, after the up-pipe? I think 1150 is a good long-term safe number. If it's right in front of an exhaust valve in the exhaust manifold? Might well be a couple hundred higher than that. Post turbo? Probably lower, like 950 or something.
Also, short jumps(60 seconds or so) above that shouldn't be a problem; while the exhaust might be 1300F, the metal around it takes time to heat up. And there is a decent bit of cooling for the aluminum pistons, in the form of oil jets spraying it from the bottom.
So try to keep long-term temps down, short-term spikes probably won't hurt much.
Dash mounted gauges are in a box I built out of some scrap aluminum I had lying around. Not perfect but it gets the job done and I would rather build something than buy it.
I had to add a second fuel gauge, long story, and threw in a voltmeter at the same time. I modified parts of the original ash tray, fabbed up the rest and welded it all together to get the finished product. Since I don't smoke and had other plans for a aux. power plug this turned out to be a great use for the space. As a bonus the wiring for the factory light in the cigarette lighter worked perfectly as dimmable power for the gauges.
Gary Lewis
46
07-26-2014 07:31 AM
snaponprofile
Ford Truck Parts for Sale
04-18-2011 12:21 PM
Waltdog
25
12-29-2010 04:48 PM
