Holley carb users, advice needed!!!
Old Sep 27, 2016 | 01:16 PM
krazyness's Avatar
krazyness
Just realized that I do have a spring in my vacuum secondary (didn't pay attention to which color but it was what looked like a medium stiffness based on pictures). For some reason I was thinking the spring was supposed to be out side of the housing for the diaphragm. Sorry for the misinformation. This was only my second carb rebuild (first holley and first 4bbl rebuild) so still learning vernacular and what not.
Old Sep 27, 2016 | 01:49 PM
tbear853's Avatar
tbear853
Originally Posted by krazyness
Just realized that I do have a spring in my vacuum secondary (didn't pay attention to which color but it was what looked like a medium stiffness based on pictures). ... etc ...
Well, I figured you did when you said didn't open .... either that or someone had blocked it off from vacuum or it had a huge hole in the diaphragm.
Old Sep 27, 2016 | 02:09 PM
krazyness's Avatar
krazyness
Brand new diaphragm, I was just being dumb lol. Didn't realize the spring inside the housing was the spring I thought I was missing... Just a dumb moment or two.
Old Sep 27, 2016 | 03:11 PM
DB429SCJ's Avatar
DB429SCJ
This carb is an 1850, correct? If it is, factory specs: primary main jet -65. Secondary metering plate- #9. Power valve- 6.5. Pump nozzle - .025. Remember,this carb was on a chevy,so it must be brought back up to the higher performance standards of a FORD.
Old Sep 27, 2016 | 03:16 PM
krazyness's Avatar
krazyness
Number on the horn is 80457-S so maybe? I don't know specifically. That should at least be a good starting point though I would imagine.
Old Sep 27, 2016 | 09:56 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Well, the stumble is from either lean or rich, momentarily. So, I presume that the shot of gas is either running out before the primary is pulling through the venture or the primary pulling and the extra gas is too much, cams never made much difference to me, position did though. does the rpm flash up then die off then roar back or does it stumble, sputter, then roar up? Make a change in some manner to give a longer, more even shot and see what happens, it should get worse or better, that will tell you which way to go. Another issue is lookto see how far open the secondaries are at idle. If the transition circuit is exposed, then you are pulling gas there all the time, meaning the pump needs to try to compromise for that extra from idle, meaning usually a rich condition. The other thing that Ihave had cause this was a bad check valve in the pump, either the ball holding the fuel up at the nozzle is bad or the check valve in the float bowl are bad, or both. Checkthese things, with the biggest accelerator pump known to man it wont work like that.
Old Sep 28, 2016 | 03:11 AM
boingk's Avatar
boingk
Here you go, this has a listing of all parts inside under the 'Parts & Kits' tab:
https://www.holley.com/products/fuel...parts/0-80457S
- boingk
Old Sep 28, 2016 | 10:18 AM
Tim C's Avatar
Tim C
What's your timing at? Give it more idle timing and see if the bog goes away. If the vacuum advance is hooked to ported vacuum you can switch to manifold vacuum as a test too, that will bump the timing higher at idle speed but otherwise it'll be stock.
The transition slot needs to be squared up too. If too much slot is sho you'll get a bog. Look it up online, there's tons of pictures.
Remember the old saying goes: 90% of carburetor problems are in the distributor
Old Sep 29, 2016 | 07:56 AM
tbear853's Avatar
tbear853
Timing ..... mine does great with a aftermarket quick advance kit installed, vacuum run to ported on carb, and to set timing I disconnect vacuum, plug port, speed engine up to where advance stops which is pretty quick, and set at 35 degrees BTDC .... then just reconnect vacuum and remove timing light. In high vacuum it can advance way past 40, but on a pull, it's only centrifugal.
I marked HB to 40 degrees years ago. I have tried straight manifold vacuum but I get pinging at times, seems happiest with ported.
Originally Posted by Tim C
... etc ... old saying goes: 90% of carburetor problems are in the distributor
New one on me ..... but I get it!
allwthrrider
Feb 1, 2012 12:25 AM
allwthrrider
Aftermarket Products
Jan 30, 2012 09:05 PM
SteveT
Nov 23, 2010 10:00 AM
Randyb12
16
Mar 21, 2006 07:27 AM
gingerbreadmaniac
Jun 14, 2005 08:53 PM
