fuel pump test
Old Aug 21, 2003 | 08:10 PM
Redi's Avatar
Redi
fuel pump test
I have a 1989 F-250 standard 4x4 w/5.0 Liter engine. I can't hear The fuel pump activate when the key is turned. Both fuel tank pumps are new. Is there a way to check the rail fuel pump with out buying a new one or what test should I run?
Old Aug 21, 2003 | 09:23 PM
pfogle's Avatar
pfogle
fuel pump test
Buy a fuel pressure gauge. Hook it to the shrader valve and turn the key. You should see pressure indicated on the gauge.
Old Aug 21, 2003 | 09:29 PM
Redi's Avatar
Redi
fuel pump test
pfogle, Where and what is the shrader valve? Am I looking for a certain PSI or just indicating pressure? Thanks
Old Aug 22, 2003 | 05:23 AM
kmichaelb's Avatar
kmichaelb
Smile fuel pump test
On the front of the left fuel rail there is a fitting that is the same size as the the valve to air up a tire. Hook up the gauge there. You can get a fuel pressure test gauge at an auto parts store, Sears also carries them. I think the pressure should be around 40 psi.
kmichaelb
Old Aug 23, 2003 | 12:26 PM
steve83's Avatar
steve83
fuel pump test
Get a Haynes manual (~$12 at most parts stores). It tells how to diagnose the fuel system, and everything else on the truck. It also tells you what tools you need.
