EGR Valve came apart, no what
This is because of the differences between the years and the programming
they run on. I think it 05 and up that you can't do that trick. Would need to
verify what year that started. However I know that your 06 can't.
You will still get a CEL do to insufficient flow. The AI2 will tattle on you.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Well that sucks. The CEL will bother me. So maybe I will just install the valve correctly. Ergh
FICM tune doesn't raise cylinder pressure, but it doesn't tune the transmission. When I had my FICM worked on by Ed at FICMRepair.com I had him add the mildest PHP tune , Atlas 40.
Based on the specs they gave when they dyno tested this tune, it was a 2wd, it put out an additional 40hp and an additional 130 ft lbs of torque. Iam probably not seeing all that dyno'd specs, but it does help.
The parallel EGR valve only works with the early trucks without setting a code and having the software take into consideration that there is not sufficient EGR flow.
For your truck with the blue smoke you need to install the valve to eliminate that.
For the early trucks the parallel valve accomplishes most of everything that an intake plug does, blocking EGR flow, but it's been stated that a disconnected valve will allow turbo over boost to blow off to the exhaust.
There's 13 years of threads about blocking the EGR. Some of theoretic benefits are the EGR college will not get as hot without gas flowing through it (although an '03 has a more heat tolerable cooler), and better mpg and power since the combustion event is not muted by the reduction in oxygen. The downsides are with a more robust explosion you risk head gaskets more so. I don't buy that as the EGR gasses are only utilized during low to moderate fueling, such as idle or cruising, not during high fueling events when the most power is asked. Although I've never seen the combustion pressures. The other downside is many report higher exhaust temps by 40-50F during highway driving, which I would expect since again the combustion event is not muted with a longer, cooler burn time, but more violent. After all, the purpose of adding EGR gasses is to reduce the combustion temperature thereby reducing NOX.
Your right, there are too many threads and posts to count on this subject and so many conflicting remarks when searching.
Probably why it still gets brought up.
I have been told that 2005 and newer will turn on the CEL with low EGR flow for any reason, and ANY YEAR will do it if the ECM was flashed to the most current firmware.
1957F100
06-10-2011 09:17 AM
