Sponsored by: Real Truck
Always on/Switch backup camera
Old Sep 26, 2016 | 09:19 AM
Krookz's Avatar
Krookz
Originally Posted by PJJTLC
I used the same head unit as Krookz. (Did the Maestro for steering wheel controls) Added two cheap plate mount front and rear cameras (both were $20 each). The rear i did wire into the reverse lights, but have the option to switch it to a switch as I ran the extra wire for it).
I don't have the upfitters, maybe next year, but did use this switch set: Pilot PL-SW16 4 way Gel Panel Switch
To switch the front camera and have two open switches for what ever in the future.
Good Luck,
Pete
2016 F250 XL SRW Crew, Gas, FX4, Trailer package
Do the gauges work correctly with your mastero? I get wrong readings on everything but the voltage.
Old Sep 26, 2016 | 11:44 AM
JeepPuller's Avatar
JeepPuller
I had a brief, only one time at first, issue with my fuel gauge. It went away upon next startup, and has not come back.
Old Sep 26, 2016 | 12:47 PM
Krookz's Avatar
Krookz
Hmm. I might have to run through the setup again. My EGT never goes 114*, oil temp sits at 109 and somehow i get better MPG the harder I push the pedal... i wish.
I posted that front cam pic for you too if you didnt see
Old Sep 26, 2016 | 03:29 PM
ligito's Avatar
ligito
Here ya go... Bigger if you click it[
Is the camera the black thing on your plate, or the shiny thing under your center grille bar?
Old Sep 26, 2016 | 04:01 PM
Krookz's Avatar
Krookz
JeepPullers is the shiny thing under the emblem. Mine is black attached to the top of the grill slats
Old Sep 27, 2016 | 06:23 AM
JeepPuller's Avatar
JeepPuller
Something seems off...
Yes, I saw them. I notice you see 'less' of the front bumper with your camera placement. Not enough of a difference to relocate. Thanks for posting.
Old Sep 27, 2016 | 06:24 AM
JeepPuller's Avatar
JeepPuller
As Krookz states my camera is the shiny object just below the crossbar under the emblem. The black thing on my front plate is an EZ Pass.
Old Sep 27, 2016 | 09:53 PM
PJJTLC's Avatar
PJJTLC
Never had an issue, everything was fine. Mind you i didn't check the gauges on first power up. It was maybe the third or forth time.
Old Oct 28, 2016 | 10:16 AM
kirk knowles's Avatar
kirk knowles
Wireless Backup Camera Installation blue wire
I have a 2008 Ford F350. The backup camera system I purchased at Amazon for has a monitor that has a blue wire in the harness that plugs into the monitor. The papers that came with the system calls this wire the backup activation wire. This system is wireless. I want to hook it up like mentioned above to come on when I turn on my Upfitter switch. Can I just hook the blue wire to the upfitter switch that i plan on running the power wire to the monitor on or does it need to be on it's on upfitter switch? The wireless receiver and monitor will be put on the same upfitter along with the wireless transmitter at the camera so that one upfitter turns all of it on at one time. The blue wire has me puzzled where to power it from.
jwhopson
Dec 31, 2013 12:53 PM
andrewbragg
May 16, 2013 09:31 PM
cray0971
Aug 25, 2011 08:46 AM
cgah04
2004 - 2008 F150
Aug 13, 2008 10:04 PM
