Looking for a computer for a lightning
Old Sep 19, 2016 | 06:54 PM
Ron94150's Avatar
Ron94150
I'm in search of a computer for my FIL's 94 lightning. It had a blown capacitor, and my wife replaced it, and on eye inspection, she recommended replacing the entire thing. (cut me a break guys, she works at denso and her job is inspecting and hand repairing boards that the robots screw up, she probably solders as much or more as anyone on here she was upset with this repair, but she was using a cheaper butane solder gun instead of her good one at work). Sure enough, that circuit is bad. Was hoping someone may have a used one laying around or can point me in the right direction for one at a decent price. Cheapest I've found so far is eBay at 299. Anyone that I can send it to for rebuilding with quick turn around. Site sponsor maybe?Name:  photo117.jpg
Size:  839.5 KBName:  photo176.jpg
Size:  908.1 KBName:  photo294.jpg
Old Sep 19, 2016 | 09:36 PM
Encho's Avatar
Encho
The Southernmost Mod
Only found this one, and it's out of stock currently, hit the "Notify me when available" button. Other ECM I saw for 94 F-150 were around $200:
RockAuto
Old Sep 20, 2016 | 06:08 AM
Ron94150's Avatar
Ron94150
I don't see this computer number listed anywhere on rock auto. Remember it is a lightning, so it's different than your standard f150's. But thanks.
Old Sep 20, 2016 | 06:52 AM
'89F2urd's Avatar
'89F2urd
You can use any computer calibrated for 19 lb injectors, your trans configuration, and injection system (maf or sd). If you find a lightning computer, great....if not, sticking in whatever you find will get you going. Jy computers are dirt cheap.
Old Sep 20, 2016 | 09:29 AM
Ron94150's Avatar
Ron94150
I was under the impression that the lightnings had bigger injectors, but after some research, a lot of people thought they had 24's but did I fact come with 19's. So any 351 SD truck with e4od will work? How about a 302 e4od truck? No repining involved? What is the difference in all the computer numbers then, and why is the Lightning computer unique?
Old Sep 20, 2016 | 09:43 AM
'89F2urd's Avatar
'89F2urd
You should try to keep the year close, there were some subtle differences through the years....mainly two vs 3 digit codes.
Technically yes, 302 e4od computer would work if that's all you can find for now....you won't be finding many of those though.
Old Sep 20, 2016 | 10:17 AM
Diesel_Brad's Avatar
Diesel_Brad
I'm glad I have a spare for mine.
I suggest going to a Lightning forum and looking in the for sale section
Old Sep 20, 2016 | 11:24 AM
Mudsport96's Avatar
Mudsport96
I've heard that chassis cab computers are programmed more aggressively as well. There was a thread on here awhile ago that went over it, but I can't find it.
Old Sep 20, 2016 | 01:45 PM
Ron94150's Avatar
Ron94150
That's funny, newer cab and chassis actually come detuned. I've driven a cab and chassis 6.2 gas, and it was a dog compared to mine. I believe they are about 50 hp less. I guess they are doing it for longevity.
Thanks for the insight on other computers, he has gone looking at a couple local salvage yards, I'm going to look on the lightning forums for an actual lightning computer.
Old Sep 20, 2016 | 06:56 PM
GoinBoarding's Avatar
GoinBoarding
I was going to say the same about the HD trucks typically being detuned. I don't know that the OBS were that way, but I doubt it.
Lots of misinformation out there...mind your sources.
Old Sep 20, 2016 | 08:02 PM
Ron94150's Avatar
Ron94150
Well, found a computer out of a supposedly 351 e4od truck. Truck started and ran, then would not go into gear. Pulled it down into first and first is all it had. I'm guessing pulling it into 1st manually engages it vs drive being electronically controlled. After it ran for a few minutes, it began to miss. Threw the original computer back in and it ran fine and shifted through all gears, just extremely hard.
Old Sep 21, 2016 | 07:47 AM
Ron94150's Avatar
Ron94150
Auto zone says they can send it out for a rebuild for 130. Only catch is, if it's not rebuild able they still charge 75. My guess is if they can't just solder in a capacitor or diode, they will say its unbuildable, and I'm guessing that's what they will say about this computer.
Old Sep 21, 2016 | 08:41 AM
'89F2urd's Avatar
'89F2urd
That's a strange set of symptoms you've developed, the "351 e4od" computer may not be for e4od at all, pulling codes would shed some light on that.
Hard shifts are a result of a miscommunication with the tranny...can be a bad sensor, bad computer, or perhaps a computer that isn't designed to control it. I've never put a non computer controlled computer into a computer controlled trans so I dunno what the results would be for that.
Old Sep 21, 2016 | 09:28 AM
Diesel_Brad
IIRc the lightning has a different firing order than its 351 brother
Old Sep 21, 2016 | 10:16 AM
'89F2urd's Avatar
'89F2urd
I've never heard that the sd lightning is sequential, but even if it were it would still run fine with a normal batch fire computer.
