Searched it. Egr delete
Old 09-17-2016, 06:57 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
Will doing an EGR delete effect anything in a bad way? Any suggestions?
Thanks
1999 f250 5.4 4x4 automatic 235k miles
Old 09-17-2016, 09:38 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
The EGR system is software driven hardware.
If you block the EGR off the software will detect it as a fault and set code and CEL lamp.
You can't defeat software with a mechanical block off.
What happens during it's normal operation is the ignition timing is advanced and fuel is cut back helping to improve fuel mileage a bit plus helping to clean up emissions out the exhaust..
It's your call if you want codes and CEL and or Emissions test failure, if you need that.
Otherwise the motor will still run.
If the EGR system is operating properly, deleting offers no improvement in performance.
Good luck.
Old 09-17-2016, 10:17 PM
02GrayPowerStroke
Thank you for your reply
olfordsnstone
08-20-2013 11:14 PM
jstarr
10-08-2010 06:27 PM
Jedi Engineer
1997 - 2003 F150
07-07-2010 09:14 AM
sevensurfer
1997 - 2003 F150
05-27-2010 11:51 PM
the_sharkster
03-07-2007 02:04 PM
Quick Reply: Searched it. Egr delete
