Krown Rustproofing Spray Today..PICS
Old Sep 16, 2016 | 06:41 PM
jackfordsd350's Avatar
jackfordsd350
Had my truck sprayed today. Here is some pics for those not familiar with the product. I have been using this for at least six years and have been very happy with the results, even with our harsh salt applications in this region.
Old Sep 16, 2016 | 07:40 PM
Xwild's Avatar
Xwild
Nice.. what's that cost? And do they get the calipers and caliper brackets and stuff too?
Old Sep 16, 2016 | 08:09 PM
jackfordsd350
$139 for the big trucks. They hit most areas. I get a couple of cans of the product for touch up. Great stuff, it actually penetrates spot welds and displaces water. Still allows easy access to work on everything.
Old Sep 16, 2016 | 08:18 PM
fordman19762003's Avatar
fordman19762003
does it dry or stay wet?
Old Sep 16, 2016 | 08:25 PM
Xwild's Avatar
Xwild
What location did you get it done at? I see there are 2 up in the Syracuse area.. And that's pretty much the closest ones to me...
Old Sep 16, 2016 | 08:37 PM
Souperchicken's Avatar
Souperchicken
Do you recoat every year?
Old Sep 16, 2016 | 09:14 PM
jackfordsd350
I had it done just outside Canandiagua NY in Stanley NY. It should be done every year. If you need to call. 585 526 2011. Mention me and they should give you a discount.
Old Sep 16, 2016 | 09:16 PM
jackfordsd350
Stays wet.
Old Sep 16, 2016 | 11:33 PM
Blk04Snake's Avatar
Blk04Snake
I've got a guy about 15 miles from me that does Krown. I think I may have the bottom of mine sprayed when it comes. I know we had trucks at work done by a place that uses a similar spray on coating that drilled holes in the rockers and bottoms of the doors but being an aluminum body I'll make sure he doesn't do that to mine.
Old Sep 17, 2016 | 10:32 AM
jackfordsd350
Only had 4 holes drilled in the doors. The rest of the truck had access already there. The tailgate had a hole in each side already.
Old Sep 17, 2016 | 11:33 AM
EightySecond's Avatar
EightySecond
Do aluminum doors need sprayed?
Old Sep 17, 2016 | 11:52 AM
jackfordsd350
Yes. Aluminum will react to salt and corrosives. It will not hurt the aluminum to be sprayed. The spray is also great on wires to keep moisture out. The battery terminals are also treated. At this point, I am thinking after all the years I have used this product, this is the way to go IMO.
This is my 2000 F 350 after all the winters with Krown spray..
Old Sep 17, 2016 | 04:10 PM
Xwild's Avatar
Xwild
Wow.. do you USE it during the winter? My 2010's frame is completely rust covered. And my cab corners are getting some rust under the paint. And I've only got 55000 miles on it.
Old Sep 17, 2016 | 04:19 PM
jackfordsd350
It's a great product. Truck has been thru the winters and the paint and body have no issues. I have the truck for sale on this forum. Lots of pictures in the ad.
Old Sep 17, 2016 | 06:18 PM
EightySecond
Well that 2000 F350 pic sold me. Goodness gracious!
Did you keep it or trade it?
