93 E4od wiring Questions
Old Sep 14, 2016 | 07:02 AM
rnfordahillshick's Avatar
rnfordahillshick
Hey guys, Im having an issue with the wiring for my 93 Idi's E4od. Its the connections that sit by the driver side kicker panel under the dash. Someone previously hacked into the wiring and none of it match up. At least i think thats what my issue is. The truck will not shift in Drive at all and i have to rev the crud out of it to move. its like its slipping. But i can manually put it in 1 or 2 and it will drive normal in those gears. What im really looking for is the wiring diagram for those connectors. when i wiggle them and/or play with them the trans sometimes starts working. Thanks guys
Old Sep 14, 2016 | 12:08 PM
southern-old-bold's Avatar
southern-old-bold
If you are sure that the connector is the problem, I would go search for your model truck in a junkyard and clip the piece of harness to match out of it to use as your wiring diagram
Old Sep 14, 2016 | 06:19 PM
rnfordahillshick
These are the plugs I'm talking about. Anyone know what they are for or what they do? Any help would be great thank you
Old Sep 14, 2016 | 09:50 PM
khconstruction's Avatar
khconstruction
I can snap pics on Friday since i have a 94 torn down with entire harness exposed if you're still in need, but i dont have a right now solution for ya
Johnny Bellardine
15
Sep 13, 2022 01:22 PM
nrbacarl
Apr 4, 2016 01:26 PM
Custom66Cab
Apr 4, 2013 06:38 PM
Heavy One Fifty
Oct 25, 2010 08:40 PM
arobe06
Aug 31, 2007 01:57 PM
