Quick steering question
Old Sep 13, 2016 | 12:06 PM
Skydivelout's Avatar
Skydivelout
Pretty sure I need to order Moog's kit for my steering, ball joints etc also have a feeling I may be up for two new front bearings. My question is how do I know if I need to do anything with my sway bar links? Can you replace just the bushes on those if they're shot?
Cheers
Old Sep 13, 2016 | 12:50 PM
Skydivelout
So just jacked up the front end I can't get any 12/6 o'clock play at all on the wheels I'm assuming h bearing check is a rocking rather than vertical motion?
Old Sep 13, 2016 | 12:51 PM
knottyrope's Avatar
knottyrope
go with something that has lifetime warranty for BJs
jack up front end and the check for smooth turning and slop
Sway bar links dry rot, I use urethane when replacing them and on the frame bushing.
They make kits that are not expensive on ebay and amazon or fav shopping place.
Old Sep 13, 2016 | 09:28 PM
hydro man 17's Avatar
hydro man 17
May also need a Redhead stearing box. Do the other wor parts first just to be sure, but if all of those compnants are bad the box is suspect as well. If you do need a box don't waste your time with "rebuilds" from the usual parts stores. A$$$k me how I know.
Old Sep 14, 2016 | 05:17 AM
AllaboutMPG's Avatar
AllaboutMPG
Yes , 12 to 6 rocking motion. Sounds like your hub bearings are ok. You can move the drive shaft up and down where it enters the back of the hub bearing to check the needle bearings. If you end up doing ball joints you'll get a good look at them anyway when you have it all apart.
stowbilly96
Sep 6, 2017 03:23 PM
mcali2
23
Aug 5, 2016 01:51 PM
SUPERDUTY OUTLAW
21
Jun 14, 2010 08:03 PM
lanekcmo
1978 - 1996 Big Bronco
Aug 22, 2003 06:53 PM
bluepony79
18
Oct 9, 2001 10:35 PM
