Engine mounts
Old Sep 13, 2016 | 03:45 AM
Johno.h's Avatar
Johno.h
Engine mounts
Hi guys got a 351 Clevo in f100 2wd. I need to replace both engine mounts just wandering if this is possible without removing engine? And if it is possible, can u loosen engine mounts from underneath and Jack up engine with a 3 tonne hydraulic teolley Jack from the sump? Just not sure if the sump is strong enough to Jack up engine ? Thanks
Old Sep 13, 2016 | 05:21 AM
Johno.h's Avatar
Johno.h
On roadworthy that I attempted to get it said left motor mount needs replacing just wandering how many motor mounts is there? Is it just the two side ones or is there front and rear mounts aswell
Old Sep 13, 2016 | 05:59 AM
Franklin2's Avatar
Franklin2
2 side and one in the rear under the tranny. You can jack the engine up, just make sure you use a piece of wood that goes out to the edges of the oil pan to distribute the weight to the edges where the pan is strong. Pushing up in the middle of the pan will bend it.
Old Sep 13, 2016 | 09:55 AM
FuzzFace2's Avatar
FuzzFace2
Also make sure the fan clears the radiator & shroud. Check to make sure nothing else is going to be close when motor is jacked up.
Dave - - - -
Old Sep 13, 2016 | 02:56 PM
Franklin2's Avatar
Franklin2
Yes, the fan will most likely hit the shroud.
Old Sep 13, 2016 | 07:49 PM
Johno.h's Avatar
Johno.h
I'll just unbolt the fan or shroud, were else is a strong point to Jack from? Is it possible to Jack up from the harmonic balancer? Also how high roughly do I need to Jack it up? 2 inches?
Old Sep 14, 2016 | 07:26 AM
FuzzFace2's Avatar
FuzzFace2
I have used the balancer as long as it's just the 1 end of the motor you are lifting.
As for how high? As high as needed. Thinking a little more than 2 inches maybe 4?
Dave - - - -
Old Sep 14, 2016 | 07:29 AM
rowdyredneck's Avatar
rowdyredneck
I've used the balancer to lift the front of the engine but I don't like to. Just be careful so you don't bend the crank snout.
Old Sep 14, 2016 | 01:47 PM
kr98664's Avatar
kr98664
Here's my experience jacking up a 351W. Procedures for your motor should be similar. I lifted from under the oil pan. I used a thick block of wood with a layer of styrofoam on top to conform to the shape of the oil pan.
https://www.ford-trucks.com/forums/1...Oil+pan+gasket
That whole write up was to replace the oil pan gasket, so obviously skip those parts.
Old Sep 20, 2016 | 06:43 AM
Johno.h's Avatar
Johno.h
Guys just a quick question, can I Jack up the engine from the gearbox bell hoising to replace engine mounts?
Old Sep 20, 2016 | 09:52 AM
Franklin2's Avatar
Franklin2
No. Too much weight hanging out the front. Piece of wood on the pan always has worked for me.
Old Sep 20, 2016 | 08:00 PM
kr98664's Avatar
kr98664
+1 on that. Look how close the bellhousing is to the crossmember under the transmission. That's where the aft mount is located. This is your pivot point to lift the engine sticking way out front. There's just so much leverage. You'd probably break the aft mount and lift the transmission instead of lifting the engine.
Old Sep 21, 2016 | 08:20 AM
Johno.h's Avatar
Johno.h
Okay so we're can I Jack it from? I know that you guys said the oil pan, were anouts on the pan? Can I put a price of wood under the pan were the drain bolt is and Jack it up from there?
Old Sep 21, 2016 | 10:56 AM
FuzzFace2's Avatar
FuzzFace2
The oil pan has a large flat bottom put the wood between the jack and that large flat bottom.
The wood will spread the weight of the motor across the full bottom of the pan.
Go easy at first to make sure you have nothing holding the motor in place thatwould put more weight on the oil pan.
Dave ----
Old Sep 22, 2016 | 06:39 AM
Johno.h's Avatar
Johno.h
Thanks for the help mate
