Cps problem? Need help!
Old Sep 13, 2016 | 07:56 PM
Haywire-Powerstroke's Avatar
Haywire-Powerstroke
The pics are of the connectors under the cover. And I believe that one pin is just the light on that photo because i double checked and the plastic and everything looks fine on both of those
Old Sep 13, 2016 | 07:59 PM
madpogue's Avatar
madpogue
What do the connectors on the gaskets look like?
Old Sep 13, 2016 | 08:13 PM
Haywire-Powerstroke
Old Sep 13, 2016 | 08:14 PM
Haywire-Powerstroke
The first two are on top of cover and the second 2 are under
Old Sep 15, 2016 | 10:24 AM
Haywire-Powerstroke
I ohmed the valve cover harness and all the injector pins on that side come out to 4.4-5.0 ohms. I think I may have found 3 bad glow plugs in the process because i ohmed them and only got a reading on one, the other three were dead. I'm going to try and do an idm swap with my dad's truck and see what happens. If the idm is good, what else could it be?
Old Sep 15, 2016 | 11:06 AM
knottyrope's Avatar
knottyrope
If IDM don't fix it then you need to buy a scanner that can read your truck and will help in the future of troubleshooting.
Or you can spend $1000s in parts guessing the issue.
Old Sep 15, 2016 | 11:49 AM
Haywire-Powerstroke
I'll have to look but I believe I have one of those vgate Bluetooth scanners that you plug in and read with that torque app from a long time ago but iirc I couldn't get it to work quite right or connect. Not sure if I need a different Bluetooth dongle (I think they call them) or if I just didn't do it right. I'll try messing with that when I get home this afternoon.
Old Sep 15, 2016 | 12:35 PM
madpogue's Avatar
madpogue
Over on "the Nation", there's a huuuge long thread on the Torque Pro / bluetooth solution and OBS trucks.
Old Sep 15, 2016 | 12:47 PM
Haywire-Powerstroke
Okay I'll have to take a look at that and see what I can come up with for a scanner
Old Sep 15, 2016 | 01:00 PM
knottyrope's Avatar
knottyrope
https://www.amazon.com/Vgate-Bluetoo...rds=vgate+OBD2
Torque Pro
https://play.google.com/store/apps/d...g.prowl.torque
Use the communication in the profile
SAE J1850-PWM
make sure you add in Ford PIDs
https://play.google.com/store/apps/d...ch.CarGaugePro
people like it cause it will pull codes but i have no bought it yet
Some OLD PCM's have to be flashed before you can pull codes
Old Sep 15, 2016 | 02:22 PM
Haywire-Powerstroke
Yup that's the same scanner I bought. I'll download that app when I get home and try to get some codes
Old Sep 19, 2016 | 07:43 PM
Haywire-Powerstroke
sorry i havent been able to update recently, my phone broke. so i finally figured out that it was the IDM that was bad and causing problems. found one at the junkyard for about 22$ that is working great so far. i was curious so i took the old one apart and found out that it was full of water. thanks to all that helped, much appreciated
Old Sep 19, 2016 | 07:59 PM
  #28
z31freakify's Avatar
z31freakify
Glad you reported back man and fixed your problem.
Old Sep 20, 2016 | 09:58 AM
  #29
knottyrope's Avatar
knottyrope
make sure you seal up your new one well
Old Sep 21, 2016 | 09:45 PM
  #30
Haywire-Powerstroke
I was wondering why the old one got water in it because it appeared to be sealed fairly well but I might do the idm mod and that'll give me a chance to take it apart and reseal it
