F600 Dump
Old Sep 12, 2016 | 12:32 AM
FordTruckGuy96's Avatar
FordTruckGuy96
F600 Dump
So I am buying this dump truck, it is a 1971 F600. I would like to find out information on the axles and engine. I have a picture of the door tag, would one of the other tags possibly have more information? I know the truck has a 361 v8, but other than that I don't know. Is there a way to tell the transmission? It has a gear shifter, would that be for the axles or the trans, how would I tell? Any help is apperciated. Vin is F61ECL86971
Old Sep 12, 2016 | 03:15 AM
GaryKip's Avatar
GaryKip
This will get you started until one of the guys comes on, with more info:
http://fordification.com/tech/VIN71.htm
of course that link only covers up to F350, but some info may apply.
Old Sep 12, 2016 | 11:01 AM
FordTruckGuy96
Yeah I had found that link, I got the vin decoded but it just tells me that the truck is a 1971 F600 with a 361 v8 built in June. From the P.O. I know that the truck has a dump body with a two-speed rear end. But he didnt tell me how to shift it.
Old Sep 12, 2016 | 06:41 PM
JEFFFAFA's Avatar
JEFFFAFA
1964/72 Ford used trans code "A" for:
64/65 Ford 3 speed manual.
64 5 speed Fuller SW74.
64/72 New Process 435 *******
66/67 5 speed Dana (Spicer) 8052.
The "B" in F2B stands for 5500# front axle.
"F2" stands for 2 speed Eaton model 15201. 15000#. 5.83/8.12 ratios. There should be a switch on the shifter with a red ****. **** up is for one ratio and **** down is for the other. You don't have to shift the rear end unless you are carrying a heavy load. I would suggest clutch pedal down when you shift the rear end. Hopefully the shift mechanism still works.
Old Sep 12, 2016 | 10:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965 F100/350 - TRANS code N = New Process 435.
NP435 introduced in these trucks in 1965.
Old Sep 13, 2016 | 08:58 AM
FordTruckGuy96
So find out if it has a 4-speed or 5-speed and yes the rear axle does still have a working 2-speed function
Old Sep 13, 2016 | 09:47 AM
NumberDummy
F61 = F600 2WD
E = 361 2V FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
L86971 = 1971.
156" Wheelbase.
T = Candyapple Red.
F617 = F600 2WD .. 20,000 lbs. GVWR
4 8: 4 = Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F2B:
F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity.
B = Ford 5,500 lbs. Capacity Front Axle.
20,000 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
450802:
45 = Davenport IA (thru 1971; Lansing MI 1972 and later) Ford District Sales Office, where the original selling dealer ordered the truck from.
0802 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Sep 13, 2016 | 10:08 AM
FordTruckGuy96
Wow thanks, that's a lot of info. I've been looking at sites trying to find the info, but most only go up to f350
Old Sep 13, 2016 | 10:34 AM
JEFFFAFA's Avatar
JEFFFAFA
I guess Ford couldn't make up their mind. My 64/72 Ford Truck slide T1 dated Jan 1975 shows these codes for the New Process 435:
Code A is 64/72,4 speed, Synchronized, New Process, 435 (General Information page 75)
Code N is 64/65,4 speed, Synchronized, New Process, 435 (General Information page 76)
So 1964 and 65 could have had either code on the warranty plate for the New Process 435. Maybe A was for 600 series and heavier and N was 350 and lighter. Who knows.
Old Sep 13, 2016 | 11:12 AM
NumberDummy
FoMoCo confusion:
1965 F100/350 used the N TRANS code for the NP 435, and...
1965 F100/350 used the D VIN engine code for the 352 2V .. 1966/67 F100/350 used the Y VIN engine code for the 352 2V, and...
1964/65 330 2V M/D; 330 2V H/D & 361 2V FT engines used different VIN engine codes than 1966/78's used for these FT engines.
Old Sep 13, 2016 | 11:47 AM
FordTruckGuy96
What would the bolt pattern be for these trucks? Or is a wedge style way of mounting?
Old Sep 14, 2016 | 01:31 AM
GaryKip's Avatar
GaryKip
Bolt pattern on what?
Old Sep 14, 2016 | 07:00 AM
FordTruckGuy96
I figured it out, the truck has the wedge style on mounting the tires to the truck, wasn't something I had looked at to begin with
Old Feb 1, 2022 | 11:47 AM
Jasun76's Avatar
Jasun76
Having trouble finding the right starter, can anyone help? 1971 Ford f600 dump truck 300 6 cylinder
Old Feb 1, 2022 | 10:40 PM
F10B1317's Avatar
F10B1317
I am not positive about the F600 because the flywheel and transmission could have been different than F100-F350. I do know there are 2 different spline counts used on the 300: 164 tooth for the ~14" flywheel and 184 tooth for the ~15.5 fly wheel. If you have the old one and it just fried but didn't have major wear on the gears then Napa ought to match the numbers on it. I would have to imagine it's this one though... https://www.rockauto.com/en/moreinfo.php?pk=1001442
