I took the air dam off my F-150 and while nearly as big as the one on the '17 SD trucks, it makes the truck feel a bit loose in the front as I approach a higher speed. I like the looks of it off but it feels better on the road with it on, so I'm putting it back on.
The ground effects (currently known as air dams) really start to kick in over 112 mph. Thanks for testing the theory!!!
Air dams in some designs are a important part of the cooling package, i doubt this is the case with SD but i would be cautious in removing these especially if you work the truck.
CORRECT:
The air dam diverts the air which would normally flow underneath the vehicle. This creates a void behind the air dam thus causing a vacuum rather than a pressure situation. The air through the radiator rushes down to fill that vacuum and hence the increased flow through the radiator opposed to having the a rush of air under the vehicle trying to escape upwards. In racing cars that vacuum also helps to hold the car down on the road, an effect which would not be noticeable on a truck. The same can be said for a negative rake (rear end higher than the front) in that the ever increasing space as the air travels toward the back at speed also increases vacuum and hold the rear end tighter to the pavement.
This can be seen in the stickers on the door jambs. Ford has interpreted the gps and electronic toll readings of the customers and assigned corrected axle weights for each customer's truck. The axle ratings are reflective of the driving habits already demonstrated through electronic surveillance.
Couldn't it be a tad smaller and do "almost" the same job??....lol. It does stick down pretty far. The old one didn't stick down that far on the 250/350 and it seemed to work. Now...if it can give me 3 or 4 more mpg......it's looking better every second !!
I'm sure Ford has done hundreds of hours of wind tunnel testing to get the best compromise of size/MPG/cooling benefits.
That's funny! My ecoboost truck won't go that fast, she tops out at 95 or so. I definitely noticed a difference when I took it off, maybe I was anticipating a difference, IDK.
One solution is to get the 2wd airdam.
I'm not sure about the 2017, but up until this year the 2wd dam is nearly 2" shorter and tucks up a little nicer to the bumper. I've always bought and installed them on my trucks.
Keeps things neat and clean.
To park in my garage, I have to pull all the way in, almost to wall. Well I have steps going to a storage room and I have dented my lower air dam. It is actually bent backwards and bent like that probably hurts the mpg more than if I removed it.
What do you think?
Removing it is easy, right?
Have you considered backing in so you damage the air damn?
What do you think?
You could heat it gently with a heat gun. It should have a memory and easily be formed back to original shape/
