For those concerned about bed height
Old Sep 9, 2016 | 09:44 PM
invstr55's Avatar
invstr55
I was very worried about this until I backed the old truck and new together to move my 5th wheel hitch...the picture says it all
Old Sep 10, 2016 | 01:15 AM
Juniorf250's Avatar
Juniorf250
My 5er has a 4 inch lift. I think if I set the factory hitch to its highest I'll be okay.
Old Sep 10, 2016 | 09:22 AM
Rasty1's Avatar
Rasty1
Thanks for sharing the pic, answers many questions!
Old Sep 10, 2016 | 09:28 AM
System's Avatar
System
Prolocutor
Good comparo. Thanks for posting!
Old Sep 10, 2016 | 09:57 AM
2009kr's Avatar
2009kr
Looks good for the drw. The srw platinum (mandatory 20# tires) will sit about 2.5# higher, so the difference may be 4+". I'm trying to talk myself into the F450.
Old Sep 10, 2016 | 10:06 AM
invstr55's Avatar
invstr55
Keep trying, you will not regret it.
Old Sep 10, 2016 | 04:39 PM
2009kr's Avatar
2009kr
Another thing pushing me that way... I will be at or a little over the specs with a srw. My trailer is almost 42' long (spec says 39'11"), about 13' tall with the center of gravity close to 6' up in the air, and around 500 Sq feet of side to catch the wind. That is really near a worst case trailer (for a 5th wheel). If i have to swerve, that's a lot of angular inertia for the truck to handle. When you see testing at the limits, it's always a gooseneck flatbed with stone down low and near the truck.
Pushing the weight limit with an ideal trailer isn't the same as pushing the limit with a near worst-case trailer like my 5th wheel camper... one more step towards the F450.
Old Sep 10, 2016 | 04:49 PM
RubyRed350Platinum's Avatar
RubyRed350Platinum
I'm going from my dually to a SRW. Can't stand the ride of the DRW and it's always fun trying to park or go through drive-thrus. I pull a 15,800lb 39' 5th wheel and the SRW will do fine. It is well below the ratings and I only pull 5% of the time I drive my truck. The other 95% is commuting and living the life!!!
Old Sep 10, 2016 | 05:43 PM
System's Avatar
System
Prolocutor
I have absolutely no trouble with my dinasaur 2012 SC SB towing a longer, heavier, taller 5th. It's about personal comfort level. If you need more truck to do the same job, that's fine. It's a personal thing. Go with what makes you comfortable...
Old Sep 10, 2016 | 06:51 PM
invstr55's Avatar
invstr55
My TH is 26,500lbs, 46 ft long and 13'6" tall so I am grateful to have the 450. I can live without going to the drive thru
Old Sep 10, 2016 | 06:54 PM
System's Avatar
System
Prolocutor
Your a bit over your RV's GVWR eh? All the full house units max out at 24k.
Old Sep 10, 2016 | 06:59 PM
invstr55's Avatar
invstr55
Absolutely,, but only 22k on the wheels. I run with minimum fluids but it is heavy with nothing in it.
Old Sep 10, 2016 | 07:00 PM
System's Avatar
System
Prolocutor
Got ya. Those are some amazing RV's.
Old Sep 10, 2016 | 07:01 PM
invstr55's Avatar
invstr55
It is all about the frame and construction...
Old Sep 10, 2016 | 07:09 PM
System's Avatar
System
Prolocutor
I know it. I wonder if they will ever expand the line. I'd love to see a 14' garage.
