6.0 Theft Ring Epidemic
The answer really is that simple. If you have a Ravelco, they'll need a tow truck to steal your truck.
I've lost count of the number of times my truck has been broken in to. It's at least six times. In any case, they've never stolen it. My faith in the Ravelco is absolute.
Usually if it has a ravelco, they might ransack the truck, but the don't even bother trying to steal it.
They've been towing the Platinum and King Ranch 2011+ as opposed to trying to bypass the ignition and PATS.
Other than that, every 6.0 I work on I recommend the ravelco. It sucks for me to put in all that time and effort, make a customers truck run like a dream, only to find out it got stolen and someone relieved them of their engine. That happened to a Buddy and his 2007 F350. I kept telling him to get some jimmi jammers and a good alarm, but no he never listened to me. One night, he took some of his customers out to a bar, came out and his truck was gone. It turned up a week later no far from where they stole it. The truck itself and the engine were rebuildable, they took the injectors, ficm, turbo, batteries, and the factory 20 inch rims.
Regardless, if you love your truck $500 and someone is way less likely to relieve you of it.
I live in South Texas where the early Super Duty is Target#1 for thieves, especially 4x4 models. I recognized this early and took action. A good solution is the Cyclops TAM anti-theft module, that install easily. Call Jeff at cyclopsantitheft.com and he will give you the lowdown.
I also purchased the Trimax TCL75 wheel chock lock that I only use together with my no-start system if I am in a shady area or away from home (like a hotel at the beach, etc.) The Trimax install on your wheel in seconds, fits easily behind your back seat (if you have SuperCab), and removes from the wheel in seconds easily. Just seeing the wheel lock can discourage thieves from proceeding.
I also purchased thru amazon the small red sticker that goes on driver's door window warning of electronic no-start security, in hope that this too discourages thieves.
I will soon add my own custom toggle switch to ground that will simply "blow" a critical fuse if a start attempt is made without the switch being "open".
Finally, I upgraded my insurance to cover theft, although they explained to me that the payout is only the blue-book value, and you guessed it, is only about 1/2 what the truck is worth.
Others may have different and better ideas but I recommend the Cyclops, using wheel lock in shady areas, and a warning sticker. You can follow me and install a second no-start manual toggle switch to compliment the Cyclops if you think its a good idea.
In South Texas most of the Super Dutys end up in Mexico, and they are a "HOT" commodity, so Ive tried to research this theft problem and take the best actions I could.
So far, So good, knock on wood.
I had to find something my wife would use, so a series of switches, magnets placed at the right place to latch a magnetic switch, etc., were all things I would do. But if the truck "walks away" because the device isn't being used, it is no good. She uses the Ravelco in all three vehicles we have it in, and franky I wish I'd had it installed on a couple of others...
Just thought I'd add in here on the Cyclops since you brought it up -- will be interested if you found a "better" way to employ it on a 6.0...
I did recognize that the Cyclops looks different from the Ford relays (stamped with Ford logo), and that any thief would recognize that, and probably the best thieves come prepared for that contingency (maybe). I thought I would sponge some black paint on all the relay casings to make them look uniform and then install my critical-fuse-to-ground toggle switch as a 2nd layer of electronic no-start.
Then, I always use the wheel lock in questionable areas, and hoping that the window warning sticker will deter theft attempts.
I may end up biting the bullet and upgrade to Ravelco.
Frustrating to see that happen after all the hard work you put into it.
Rob
!I don't know if it has the optional ignition kill on it but will try to find out.
Thanks
Thanks
use the same color wire and some grey or black potting compound
in both the key plug and the socket side.
I thought I has a 2005 Engine electronic control wiring diagram but I guess
I'll need to get one off the DVDs later tonight. You just pick some system
where opening the wire path results in a NO START issue. very easy to do.
Also I would use a female for the truck side and put some extra hot pins
(all fused) and a few grounds to slow down any probing. I would also do
more than one circuit. Once that is all done sepreate the tap points in each
circuit so the in and out are not in the same place. Yes I know it makes it more
work and they don't like work. They like to take your work.
I'll post the PDF later tonight.
Sean <BR>
6.0L Tech Folder
Thanks
Thanks
When I clicked on the sticker link, a big flowery "Peace and Love" sticked came up - kind of funny seeing that on my windows. I'll need to search that site come more.
Thanks for the info.
Thanks Dan.
I know it took 8 hours to install the Viper5000. Guy said it was hardest system he ever installed. The F250 diesel trucks are not easy installs I've read too.
Detective I spoke with said there's an epidemic of 6.0-year trucks being stolen for use in crimes in this area. Big, fast, powerful, and hard to stop was the reasoning the detective gave for singling out these trucks.
I know someone with an 06 F350 in this area who had the exact same scenario happen 6 months ago.
If it's salvageable (they won't let me see it or tell me it's condition), I want to make it as un-stealable as possible.
I've read about wiring the ignition through upfitter or other switches.
Short of installing an F16 ejector seat that I can activate by an app from my phone, what else can I do to slow down the adroit crew of F350 thieves if they try to steal her again?
After doing most of the bulletproofing, and optimistic it will run for many years, I don't want to donate it to thieves, again....
Any ideas?
So I've been following this thread to also see what suggestions there are as that has always been on my mind in preventing it from happening again. I just didn't know about what would be the best way.
