Big block mileage
Old Sep 8, 2016 | 09:42 PM
hwyhogg's Avatar
hwyhogg
Big block mileage
What mileage and what gear ratio are you running?
Old Sep 8, 2016 | 10:00 PM
98Econoline150's Avatar
98Econoline150
Not a big block but I will share anyways. 223,640 miles 14mpg 3.55 Open Ford 8.8
Old Sep 9, 2016 | 04:38 AM
Im50fast's Avatar
Im50fast
Do you consider a 415 cu in V10 a big block?
Mine has 268,000 miles and gets 12mpg and has 3.73 gears.
Old Sep 9, 2016 | 09:37 AM
Tom's Avatar
Tom
Doesn't the term "Big Block" refer to a certain GM V8 engine family? You won't find one of those in many E-series vans.
The E-vans got the FE-series 460, which is probably the closest competitor to the GM 454 that people typically think of with the term "Big Block". They stopped using these engines in 1996, and it was replaced in '97 with the 6.8L modular V10. Most with V10s report 12-13 MPG, and those with 460s tend to report a bit worse than that.
Old Sep 9, 2016 | 02:48 PM
Spaznaut's Avatar
Spaznaut
'92 'big block' around 10-12mpg. 167,000. XLT 3.23 gearing I think.
Old Sep 9, 2016 | 04:16 PM
vettex2's Avatar
vettex2
I always thought the 352-390-429 and up were ford big blocks just because the blocks were actually bigger
Old Sep 9, 2016 | 06:32 PM
blageurt's Avatar
blageurt
actually they are 3 different engine families...The only current survivor is the 460 ..Or 7.5 were Internally balanced before 1978 and Externally balanced after that until 1996 I believe...But the Parts are Interchangeble to a certain level with the 429 ...The 352 and 360-390 AND the Cobra-Jets ( 428 /429) were totally different
https://en.wikipedia.org/wiki/Ford_FE_engine
But in reference to the OP a 460 Van E350 In an excellent state of tune....you will be lucky to get 8 mpg
Old Sep 9, 2016 | 08:25 PM
EconolineFan's Avatar
EconolineFan
And here I though my 5.0 V8 was thirsty at 15 mpg.
Old Sep 10, 2016 | 02:17 PM
jeffreyclay's Avatar
jeffreyclay
Red face
I rarely get out of "the city" so my mileage stinks. My 302 w/3.23 gears and a AOD gleefully gives me 10 mpg.
Old Sep 13, 2016 | 11:55 AM
hwyhogg's Avatar
hwyhogg
Thanks for the replies. Wondering how much over drive would really net me. It's a 56 panel truck with; 460 .030 over C6 and 3.50 posi. Gets about 10mpg on hwy at 60 mph at 2500 rpms
Old Sep 13, 2016 | 07:28 PM
Im50fast's Avatar
Im50fast
No offense guy, but even if it got 25mpg, would that actually affect your life in a tangible way? Are you commuting to work in a 1956 panel truck with a 460?
I can't imagine the fuel budget is actually important for a toy.
Old Sep 13, 2016 | 07:57 PM
Tom's Avatar
Tom
I can see a substantial increase in fuel economy, perhaps even 20-30% if geared better for highway cruising. Problem is that you'd have to run a LOT of miles to pay for the swap with fuel savings.
BTW...can you post some pics?
Old Sep 16, 2016 | 04:46 PM
jayro88's Avatar
jayro88
I have a 444 ci.........
I get 15.5mpg mixed average, 16.5-17.5mpg on the hwy. Very rarely do I see anything under 15mpg.
Old Sep 19, 2016 | 10:49 PM
RangerMercMan's Avatar
RangerMercMan
I thought the 429 and 460 were the same and part of the "385" series engines. I was told over twenty five years ago by a retired mechanic that if you drill a whole "somewhere" on the engine (likely on the emissions) that a 460 will go from 8mpg to 16mpg. This would have been in the mid seventies. I am wanting a travel setup which would either be a van or a truck and trailer but of course I want mileage in the twenties
Old Sep 20, 2016 | 09:47 AM
Teutonics's Avatar
Teutonics
+1
The message you have entered is too short. Please lengthen your message to at least 10 characters.
