Carbon Build-Up
Old Aug 20, 2003 | 09:11 PM
RangerWoman's Avatar
RangerWoman
Carbon Build-Up
What is the best way to "blow some carbon out"? On the Freeway, or in my Driveway?
My F-150/302/3spd has been running like crap, so tonight I got aggressive with it and blew some carbon out while idling in my driveway.
I took it around the block and it seems to be running fine. Can't really test it until tomorrow on the way to work..........
What do y'all think?????
Old Aug 20, 2003 | 10:57 PM
Mil1ion's Avatar
Mil1ion
Carbon Build-Up
Have someone spray water (with a spray mister ) into the carb while driving.
You could put some tranny fluid in the gasoline.
Old Aug 20, 2003 | 11:12 PM
neverenough's Avatar
neverenough
Carbon Build-Up
That sounds a little dangerous for the person with the mister.
I use Sea-Foam in the tractors. Also, when ever I get a new (to me) car or truck I put some in them too. Some people don't like it, but it works for me without any problems. It works good when put in the crankcase too.
Old Aug 20, 2003 | 11:21 PM
Mil1ion's Avatar
Mil1ion
Carbon Build-Up
That was one of my comedic replies for the day.
Old Aug 21, 2003 | 05:10 AM
ackusackus's Avatar
ackusackus
Carbon Build-Up
I used my windshield washer resevoir on my old clunky volvo deisel. It worked great. Shoved the tube into the intake and hit the highway. Almost completely obscured the highway the first time I did it casue it knocked so much crap loose. James Bond would have been proud of that smoke screen. Luckily there was not much traffic out (I had no idea the results would be so dramatic). The guy who taught me how to do it said to run the water until the motor starts to run rough, then let off. When it smooths back out, hit it again...repeat as necessary. Ran much better afterwards.
I have been hesitant to do it with my truck, not knowing how the higher temps of a gas engine and the water will interact with each other. I have newer heads, but as far as I know the guts in the block are still the original deal, and I am not in a position to get a 460 rebuilt at this time.
Old Aug 22, 2003 | 09:49 AM
RangerWoman
Carbon Build-Up
Dennis, I'm a little afraid to try the water in the carb thing just yet, but will if I get desperate. How much tranny fluid should I put in? About a quart? Or less?
I'm also wondering now if it could be the fuel pump. Just read another thread where someone was having the same symptoms.....lack of power, and hardly any acceleration in 3rd gear.
Old Aug 22, 2003 | 10:14 AM
neverenough
Carbon Build-Up
I would check out the basics first. Initial timing and both advances, cap, rotor, plugs (mainly the color), vacuum, compression, etc... From there it will be easier to pinpoint the problem. Good luck.
Old Aug 23, 2003 | 03:22 PM
unreng's Avatar
unreng
Carbon Build-Up
RangerWoman,
Buy some Red Line Fuel System Cleaner and pour the entire contents in one tank before the next fill-up. This stuff is recommended by various auto companies to keep the valves clean (per the label). It's a cheap and safe fix for carbon build-up. If it doesn't remove the carbon (very doubtful), it will clean the entire fuel system.
Good luck,
Chris
Old Aug 25, 2003 | 12:50 PM
RangerWoman
Smile Carbon Build-Up
I'm doing the Happy Dance today!
Saturday I changed both of the fuel filters, and added Gumout's version of a fuel system cleaner. As of my last test drive a few hours ago, she's running almost as good as new.
I still may want to throw some good wires on it though. I will do a search and see what kind of wires you guys recommend. Anybody know how Kem's are??
Thanks for everybody's help and suggestions! (I'm sure it will be one of those things soon enough )
Old Aug 25, 2003 | 03:20 PM
unreng's Avatar
unreng
Carbon Build-Up
RangerWoman,
MSD Superconductor Wires - top of the line and some of the lowest resistance: ~100 ohms for all of my wires (won't work on an HEI distributor cap though). Plus they come with a straight distributor boot to help during removal. I've never had the boot separate from the wire in 3+ years. They also have cylinder markers to place on the wire
Taylor - Have heard that these are good quality.
Autolite - Good, but matching the lengths to cylinders can be confusing.
https://www.ford-trucks.com/forums/s...2B%25252Bwires
Good luck,
Chris
Old Aug 25, 2003 | 10:18 PM
RangerWoman
Carbon Build-Up
Chris, do they come numbered according to firing order? The Taylors, or any of them for that matter?
( And if not, they darned well should! !! .. Hrmphhh!!! LOL!! )
Old Aug 25, 2003 | 10:20 PM
Mil1ion's Avatar
Mil1ion
Carbon Build-Up
The 2 longest wires go to the 2 rear cylinder's
Old Aug 25, 2003 | 10:22 PM
RangerWoman
Carbon Build-Up
Thanks Dennis! BTW, that was fast and logical!!! Duuhhh to ME, lol!
Old Aug 26, 2003 | 12:10 AM
unreng's Avatar
unreng
Carbon Build-Up
For numbered wires, use Ford Motorsports wires:
M-12259-R301 - red
M-12259-C301 - blue
M-12259-M301 - black?
http://www.cjponyparts.com/DISCOUNT.HTM
Chris
Old Aug 26, 2003 | 12:22 AM
beeboy's Avatar
beeboy
Carbon Build-Up
Are there always 2 fuel filters? I have looked for a 2nd one on my 79 f150 -351M. It has dual tanks. I have a small filter on the carb. I have followed the fuel line from the carb, to the pump, then back until it disappears on top of the front tank. I've yet to find another filter, or the tank switch module for that matter.
