CHMSL Camera - Bed Question
Old Sep 4, 2016 | 11:04 PM
NStorm's Avatar
NStorm
For you fortunate few whom have received your trucks, curious if you would perform a quick test. I'm shopping tonneau covers, and will pull a gooseneck. Curious how far back from the front of the bed (bulkhead) the cover can rest before obscuring the pin location. For example, if I had a Bak Flip MX4, and the forward most panel was 22" wide, and 6" thick (all panels stacked on the forward most), would this block the view of the pin from the camera?
Thanks for any help that can be provided. Pics are always appreciated.
Old Sep 5, 2016 | 04:21 PM
Force74's Avatar
Force74
Hi Neis.
I took a few pictures for you. One is from the camera and it is on zoom. You can't make out the tape. I took two more from the outside with my phone at about the same angle as the camera. The measurement to the board is about 36". I think to do it right, I'll use a large piece of cardboard from work tomorrow. I'll lay it across the box and we'll see at what point it interferes with the hitch pucks. Let me know if you would like me to do that.
Old Sep 5, 2016 | 07:34 PM
MC_Greenmachine's Avatar
MC_Greenmachine
Originally Posted by Force74
Hi Neis.
Hey do it for the rest of us that'll help us size up toolboxes and or alternatives
Old Sep 5, 2016 | 07:46 PM
NStorm's Avatar
NStorm
Hi Neis. I took a few pictures for you. One is from the camera and it is on zoom. You can't make out the tape. I took two more from the outside with my phone at about the same angle as the camera. The measurement to the board is about 36". I think to do it right, I'll use a large piece of cardboard from work tomorrow. I'll lay it across the box and we'll see at what point it interferes with the hitch pucks. Let me know if you would like me to do that.
Thanks brother! If you have time, I would appreciate it, as I'm sure others would as well. Enjoy the sweet ride!!
Old Sep 5, 2016 | 07:53 PM
Force74's Avatar
Force74
I'll get it done tomorrow guys. Happy to help.
Old Sep 5, 2016 | 08:26 PM
Force74's Avatar
Force74
Alright guys. Here's my highly scientific results. 20"...too long, 18"...too long, 15.5"...seems about right. Maybe call it 15" and good. We should note that I used cardboard and a toolbox would have a much thicker dimension...thus changing the results a bit. At the same time, the hitch would be higher as well.
Old Sep 5, 2016 | 08:29 PM
NStorm's Avatar
NStorm
AWESOME! All the reps for you sir!
The pic here is what I'm thinking. Seems like it would work??
Thanks very much!
Old Sep 6, 2016 | 07:33 AM
fordmantpw's Avatar
fordmantpw
The price you pay for being one of the first to get your truck!
Mighty nice of you to take the time to do that!
Old Sep 6, 2016 | 08:51 AM
Frantz's Avatar
Frantz
For any other configuration you just need to know the Cab-axle and then the distance from bed to camera. I know we all hate math, but it can be calculated with basic trig....
Old Sep 6, 2016 | 09:15 AM
Rasalas's Avatar
Rasalas
Thanks for the research. I won't be having a tool box since I sold my Weathermaster a couple of years ago. But, here is an idea. Why not mount a mirror on the gooseneck which can be seen by the camera pointing straight down to the pin? Use the alignment in the camera until close and then watch the mirror to complete. Tool box height would be immaterial since the alignment line is on center for the y axis and the mirror could handle the x axis.
Old Sep 6, 2016 | 12:52 PM
MC_Greenmachine
With that I have an idea, probably someone else has thought about this before but I'll just run em up to the Home Depot and grab some 3.5" PVC cut to a little taller than the box, glue some disc larger than the pipe, like a lube disc for a fifth wheel, and make my own little stand and when that smacks the toolbox, boom I'm good to drop it down
Old Sep 6, 2016 | 01:19 PM
Force74's Avatar
Force74
Happy to help guys. Glad it was useful.
Old Sep 21, 2016 | 04:21 PM
WiredJs's Avatar
WiredJs
Hi Neis.
Force, do you have the LB/8' or the SB/6.75'? Is the 36" measurement to the hitch the same either way? Thanks
Old Sep 21, 2016 | 04:57 PM
Force74's Avatar
Force74
I have the short box and I don't know if the dimension is different between the SB and LB.
Old Sep 21, 2016 | 05:23 PM
WiredJs's Avatar
WiredJs
Ok. Thanks
