O-ring?
Old Sep 3, 2016 | 01:32 PM
CB3's Avatar
CB3
O-ring?
I am replacing my old water outlet/thermostat housing with a chrome version that has an "o-ring" seal. I am not familiar with this type of seal. Is this all I need or do I need to put the usual gasket and permatex sealer on the housing?
If I use just the o-ring, is gasket sealer required also?
And I have a new regular gasket with adhesive on one side. If I use this gasket, do I put permatex sealer on both sides, or just the un-adhesive side?
Thanks for any info.
CB3
Old Sep 3, 2016 | 01:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The engine size is?
Old Sep 3, 2016 | 02:50 PM
CB3's Avatar
CB3
1978 F-100, 302
Old Sep 3, 2016 | 06:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
With O-rings, just use the O-ring, no additional sealer is needed. I'm assuming there's a groove for the O-ring to fit in. You can use a small amount of petroleum jelly in the groove to help keep the O-ring in place while you install the housing.
smallello
May 7, 2016 09:31 PM
Beef150
15
Aug 15, 2013 04:09 PM
adamkat22
Jan 9, 2013 09:50 PM
jlutes
Jul 1, 2007 07:05 PM
ducedude
17
Mar 28, 2005 08:28 AM
