First stupid question
Old Sep 3, 2016 | 11:23 AM
Stogey's Avatar
Stogey
Hi guys
First of many stupid questions
Sorry, Still haven't managed to score a manual yet. By the way which one is the best?
Untill I get one, I need to get the wiper arms off to re position them, how do they come off?
I can get them to move about 1/2 inch. On Brit cars, there is normally a nut under a cover, but I can't see see one
What do I need to do?
Thanks again
Old Sep 3, 2016 | 11:30 AM
RangerMercMan's Avatar
RangerMercMan
It has been a long time since I took one off or looked at one. Try looking at the bottom of the arm for a clip that you pull out which releases it from the splines of the shaft
Old Sep 3, 2016 | 11:43 AM
SuperSabre's Avatar
SuperSabre
The wiper arms are mounted on a splined shaft. You just (very carefully if your paint is good) get underneath it and pry it straight up from the shaft. The spring loading of the blade does not help. The factory workshop manual is available in paper or on CD-ROM. Depending on how much you plan to take apart, the '64 - 72 Ford Parts and Accessories manual is a gold mine with an illustrated parts breakdown section and a list of almost every part on your truck by part number (as it was in 1975 when the manual's last edition came out). It,too, is available on CD-ROM at a very reasonable price. The paper form is easier to use, but is rare, huge, and pricey. The 1965-66 Ford F100 - F250 Illustrated Facts and Features Manual is cheap and full of interesting information. All of these are available from the usual U S F100 - F250 parts sources. I'm guessing your next question will be: Where do I get parts for this thing? Good luck with the wiper arms.
Old Sep 3, 2016 | 11:45 AM
TA455HO's Avatar
TA455HO
Lead Gopher
For most purposes I find the factory shop manual to be the best. This is the manual that the Ford dealership service technicians would have used when working on our old trucks - I find the information is much more specific to the vehicle than something like a Haynes or Chilton manual that covers a bunch of years. For 1966 there are 5 volumes in the Ford set, counting the preliminary manual. Not sure what year your truck is, but this is an example of a 1966 set.
Original 1966 Ford Truck Shop Manual Book Set Manuals Books F100 F250 F350 | eBay
If you shop around you can find them cheaper, just an example. I bought one at a time and paid less than $20 each.
http://www.ebay.com/sch/i.html?_from...nuals&_sacat=0
Old Sep 3, 2016 | 11:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pic from 1964/72 Ford Truck Parts Catalog, available on a C/D from hipoparts.com
Old Sep 3, 2016 | 12:19 PM
Stogey's Avatar
Stogey
Yea gods!
You guys are amazing!
Thanks for all the help, I will have another go in the morning
Hope you all have a great extended holiday
Barry
Old Sep 3, 2016 | 02:38 PM
SuperSabre's Avatar
SuperSabre
RangerMercMan is right - there is a small spring loaded catch on the inboard bottom of the arm to pull/pry back on while you're prying the arm up off the shaft until the bottom of the arm clears the bottom of the shaft. Did that make any sense?
Old Sep 3, 2016 | 02:39 PM
6t6merc's Avatar
6t6merc
The wiper arms seem pretty simple but can be a struggle. There's a little tab that must be pulled back to permit it to go over the spline. A screwdriver (or two) is the most-used tool but I suggest you wrap it in tape and use some small pieces of soft wood to pry against. If you can, mark the location of the arm on the spline before it pops completely off so it will go on in the same place. There is probably a Ford tool for this but I've never heard of it.
Eric
Old Sep 4, 2016 | 12:15 PM
john jamieson's Avatar
john jamieson
At least one of the larger parts suppliers sells a wiper arm removal tool. I don't remember which. I almost bought one when I couldn't get mine off. The little plastic pry bar in a door panel tool kit from harbor freight works and is less likely to chip the paint.
Old Sep 5, 2016 | 02:07 AM
Stogey's Avatar
Stogey
Great guys
First job on the truck done
Now got wipers that work, and fitted some electric washers, using the push button above the ignition key.
Whilst playing with it, I greased up the suspension etc
Nice to have something you can actually work on for a change
Cheers
Jake Driver
Mar 4, 2017 06:15 AM
brandon3244
May 28, 2014 01:44 AM
sofob0909
Oct 30, 2009 11:05 PM
Big Dummie
13
Nov 20, 2005 09:27 PM
Brian_B
22
Sep 27, 2005 05:35 PM
