Smoking engine
Old Sep 3, 2016 | 08:37 AM
demonkiller3418's Avatar
demonkiller3418
Smoking engine
A while back I did an oil change on my 1968 f100 with a 360. I got some oil on the headers and it started to burn off causing smoke, after a little engine degreaser and letting it burn it went away. But recently I patched all the holes in my exhaust system and let everything harden up and I put on new mufflers. (I haven't started the truck since June 7) and when I started up the truck, there was smoke. I let it sit for a minute just to burn anything off and its still smoking. I went into the cab to shut it off and I noticed that my oil gauge was all the way to H. Any ideas of what's wrong?
By the way even with the mufflers the engine still sounds loud by the headers.
Old Sep 3, 2016 | 08:59 AM
HIO Silver's Avatar
HIO Silver
Open the hood and look around!!! Did you knock off the wire to the sender and maybe it's grounded somehow?
Old Sep 3, 2016 | 10:11 AM
351Cleveland C4's Avatar
351Cleveland C4
How much smoke? What color? What's it smell like? Where's it coming from? Is something on fire???
Old Sep 3, 2016 | 12:33 PM
Coastal68's Avatar
Coastal68
Originally Posted by demonkiller3418
But recently I patched all the holes in my exhaust system and let everything harden up and I put on new mufflers....
What did you use to patch the exhaust? JB Weld? Where were/are the holes in the exhaust?
Old Sep 6, 2016 | 10:56 AM
demonkiller3418
Sorry I have not been keeping up with this post. I am very busy and will try to post a video.
Old Sep 6, 2016 | 10:57 AM
demonkiller3418
I was going to use jb but the guy at the store recommended muffler cement because it was a lot more for the same price.
Old Sep 6, 2016 | 10:59 AM
demonkiller3418
There wasn't a lot of smoke, just like a small brush fire. It was white and I don't remember what it smelled like but it was coming from the headers. Nothing is on fire.
Old Sep 6, 2016 | 11:21 AM
351Cleveland C4
If the headers are smoking, you just gotta let them burn off whatever is on them.
Headers temps can reach over 500 degrees. So they're gonna burn stuff.
Old Sep 6, 2016 | 11:54 AM
Coastal68's Avatar
Coastal68
So a resin based/epoxy of some kind? Just wondering if it's the plastic burning.
Not to be a smart aleck, but a small brush fire amount of smoke seems like a LOT of smoke.
Old Sep 7, 2016 | 03:19 AM
GaryKip's Avatar
GaryKip
Sounds like two problems here. 1. something (sealant, oil,or epoxy) on the headers. and 2. Something has happened to the oil pressure sending system. IF the smoke is definity coming from "something" that is on the headers, is the "something" dissipating? Or is more of the "something" coming from somewhere? As far a problem #2- Do what HIO said! Look around with the engine off first! Check all fluid levels, belts and wires. Keep wires away from the headers-including the starter power wire! Everything look OK? Then start it and have a helper look with you. Use flashlights if need be. Check underneath too.
Old Sep 7, 2016 | 12:31 PM
72CC428's Avatar
72CC428
I always brine my engines before I smoke 'em. Like to use hickory for wood.
Old Sep 7, 2016 | 01:22 PM
Brian1971f100's Avatar
Brian1971f100
I remember you had some manifolds on the grill
Old Sep 9, 2016 | 12:54 PM
JEFFFAFA's Avatar
JEFFFAFA
1ST I'd spray the headers down with Brake-Kleen to clean them off. This will clean, dissipate, and leave no residue. Now the gauge being pegged has to be investigated. Either the wire is grounded as mentioned above or the pressure regulator in the oil pump has stuck full open.
Old Sep 9, 2016 | 08:31 PM
72CC428's Avatar
72CC428
Yup, little marinade, BBQ sauce.
Old Sep 10, 2016 | 02:32 AM
GaryKip's Avatar
GaryKip
I couldn't tell if that was ATF or salmon on a cedar fence plank. But it's on the rear passenger side by spark plug #3
