Lowering rear w/ flexomatic
Old Sep 2, 2016 | 10:57 PM
hivoltj's Avatar
hivoltj
So the new '70 has flexomatic rear springs and shackles and needs to come down about 3" in the rear. Does anyone make some new lowering springs that would replace the flexomatic leaves? Don't really care if the flexomatic stuff stays or not; I figured since I can't lower it the way it is might as well get new springs. Axle flip would be too low.
Thought of tracking down some used regular springs and doing drop hangers but that's probably dumb
Old Sep 2, 2016 | 11:33 PM
351Cleveland C4's Avatar
351Cleveland C4
You could just flip the front hanger over. That results in about a 4" drop if I remember right.
OR!!
Could drop it "weigh" down...
Old Sep 2, 2016 | 11:36 PM
HIO Silver's Avatar
HIO Silver
A leaf spring hanger "half flip" would probably get ya close. Gotta correct the pinion angle though. A full flip results in a whopping 11 degrees of pinion correction. Better to cut and reweld the leaf pads if going this route. Don't stack shims but if ya do weld em together.
Otherwise, non-FOM leaf springs and a DJM shackle system....
... an axle flip is about 5.5 inches of drop.
Old Sep 3, 2016 | 12:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Sep 4, 2016 | 08:00 PM
Uni Moe's Avatar
Uni Moe
I used drop shackles and ditched my flexo springs for standard springs.
Old Sep 5, 2016 | 08:11 PM
68murc's Avatar
68murc
I used the DJM lowering shackles and hangers on my Flexomatic springs. It worked no problem. I have a thread about it here on FTE. I'd include a link to my thread but I don't know how to do that..........
Old Sep 6, 2016 | 11:13 AM
hivoltj's Avatar
hivoltj
How much drop did that get you?
I found a thread where someone had done the same but had to notch out the bed crossmember. Don't wanna do that to this super clean bed
Old Sep 7, 2016 | 06:34 PM
JEFFFAFA's Avatar
JEFFFAFA
You mean this one?
https://www.ford-trucks.com/forums/1...-kit-pics.html
Old Sep 7, 2016 | 08:18 PM
HIO Silver's Avatar
HIO Silver
Can ya post a pic of the DJM shackles installed on your FOM springs? I went through the thread linked by Jeffafa and there isn't a picture of the rear ends where the FOM system is installed.
Thanks.
Old Sep 9, 2016 | 09:07 PM
DLW-70-F100's Avatar
DLW-70-F100
For what it's worth, Detroit spring https://www.eatondetroitspring.com/ makes leaf springs for our trucks up to 3" lower, or 3" higher.
Old Jun 24, 2020 | 08:45 PM
culpthm1's Avatar
culpthm1
Picking up on this old string. My 1971 F250 Camper Special has the original Flexomatic springs. I am looking to lower the back end 2 or 3 inches so this Eaton Detroit Springs option is interesting. I don't want to have to notch my frame. If I use Eaton, can I avoid this? Also, I am wondering if I need to shorten the drive shaft if I lower the back end. Any advice regarding use of Eaton springs would be appreciated.
Old Jun 25, 2020 | 09:34 AM
Pcmdub's Avatar
Pcmdub
culpthm1,
There are different opinions and ideas on what to do with the FOM springs. I have a 71 LB with FOM springs and installed the DJM kit (almost). The forward leaf spring bracket from DJM will go in with no problems, but the rear shackle extension is the same exact height as the factory FOM triple bracket setup, so even if you install it, the spring does not move.
Here's the problem, because you only moved ONE side of the leaf, you are clocking the rear end angle about 8deg toward the sky. NOT good for the joint, so you will need a shim to make this work. I found an 8deg shim that worked perfectly and bolted it in so it won't move.
Notching the frame is done to make the axle clear the frame but you have to drop it 5" or more and then put 4 guys in the bed to hit the frame on a camper special. Swapping the rear springs with Eaton Detroit springs is expensive and will be 10% better for 200% more money and time.
Old Jun 25, 2020 | 12:57 PM
culpthm1's Avatar
culpthm1
Thanks. helpful. The extra cost is worth it to me if I can simply remove the FOMs, install the Eatons and get the 2" drop without notching, shimming, cutting, shortening or flipping.
Old Jun 27, 2020 | 04:52 PM
Pcmdub's Avatar
Pcmdub
Still have to find/buy new rear shackles and bushings. The FOMs are longer than the regular leafs and use different bushing/connectors.
Old Jul 1, 2020 | 12:46 PM
Small-Block-850's Avatar
Small-Block-850
@Pcmdub My truck is also equipped with the Flexomatic \ EZ-Ride rear shackles. Based on what you've written, will this combo complete a 4" drop?
This is the DJM drop kit + shorter length leaf springs.
DJM 4" Lowering Shackle Kit
https://djmsuspension.com/product/hs1130-4/
Leaf Springs (Non EZ-Ride Length)
https://www.generalspringkc.com/prod...QaAnGPEALw_wcB
