Sponsored by: Auxito
strange radio problems
Old Aug 20, 2003 | 05:46 PM
switchback's Avatar
switchback
strange radio problems!
Hello. I have a 98 F-150 supercab, 4.6 liter, 5 speed 4 x 4, with am/fm radio with the 6 disk CD player in the panel behind driver door. Today I totally washed the inside of cab by removing all seats and using carpet cleaner, brushes and then spraying with a hose to clean the carpet (it was FILTHY) Ok, I let everything dry (though carpet is still damp) , replace seats and noticed this:
* radio will only play the station I was listening to while washing inside of truck - volume works fine
* I cannot change radio am to fm, change channels or play CDs
*there is no panel light on the radio. It is totally dark and doesn't show channel or clock
* if I turn key and try to play radio, it won't play unless I quickly switch on then off the windshield wipers.
* the rest of truck seems to function well
Ok, I went thru my owner manual but can't figure out what is going on here. Any help will be greatly appreciated!
Old Aug 20, 2003 | 07:32 PM
AegisSailor's Avatar
AegisSailor
You sprayed a hose inside the cab of your truck?
uh, think it's safe to say that you shorted something out in the radio.
Old Aug 20, 2003 | 09:02 PM
Racerguy's Avatar
Racerguy
Seeing that the wipers make a difference I wonder if it's another one of those strange GEM problems?
Old Aug 20, 2003 | 09:40 PM
switchback's Avatar
switchback
Thanks, both! Ok, yea, maybe it was dumb to hose out inside of truck but it was filthy! Anyway, I was very careful doing it but it was about 95 deg out with 100% humidity. Would the humidity plus added moisture from the hosing have an effect on the wiring? Maybe if truck completely dries, it will be ok. Another thought - the disk player might of got wet. Would a short in the CD player screw up the whole radio system?
Old Aug 20, 2003 | 10:42 PM
evo-pete's Avatar
evo-pete
A hose used with a steam cleaner cleans the carpet just like new
i have tryed the same method on my cloth seats . I got stains out that i thought were there for good
peter
Old Aug 21, 2003 | 10:40 PM
methos5044's Avatar
methos5044
I would bet the farm that you got the harness from the changer wet and yes that would short out your radio.
ricardo sandoval
1983 - 2012 Ranger & B-Series
Sep 27, 2008 04:22 PM
Champ198
2004 - 2008 F150
Feb 1, 2006 06:19 PM
suave6565
Jan 18, 2005 11:14 AM
