New Headlight question(imnidjut)
Old Aug 29, 2016 | 01:53 PM
CharlyG's Avatar
CharlyG
I want to replace the headlights in my 2000 Excursion. I don't want the LED and odd looking things, just a replacement headlight without a cloudy exterior!.. sorry for the thread but I didn't see much help for this in the tech folders. I don't want to shine them up, just replace and be done with it.
As I'm looking around I see stock, and LED, but I am confused as to how they come? I don't think I need the amber parts, they seem fine, I just need new headlights, that are better than stock but not that much different in looks..
Help would be appreciated.
CharlyG
Old Aug 29, 2016 | 01:58 PM
DOOM173's Avatar
DOOM173
I went with the Harley Davidson style headlights.
Old Aug 29, 2016 | 02:02 PM
DOOM173's Avatar
DOOM173
Here's a side by side comparison for you. Hope this helps.
Old Aug 29, 2016 | 02:06 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Rockauto.com has replacements in either the fluted or clear lens.
I'd suggest to get the NSF certified ones from TYC as they are about as close to OEM quality you are likely to find. ( I have tried many before I found these )
About $25 bucks.
I replaced the bulbs they come with with German made Phillips 9007xv also from rockauto
Old Aug 29, 2016 | 02:09 PM
zapola6's Avatar
zapola6
I went A-Auto - Just regular headlights and turn signal... $100 I think or close to it, came with new head lamps and turn signal bulbs
Old Aug 29, 2016 | 02:39 PM
CharlyG's Avatar
CharlyG
What throws me off is the lack of amber? The plastic is amber in the stock ones. I assume you have to put a "yellow" bulb in the new ones since there is little amber to be found?
Old Aug 29, 2016 | 02:46 PM
pirate4x4_camo
The lower marker/turn lense is seperate on your year. You can get clear or Amber lens and like you say just use the correct bulb.
Many people convert to the 05 style 1 piece headlamp and marker combo.
Old Aug 29, 2016 | 03:14 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
IIRC, 2004 MY had the crystal headlight and turn housings. Those'll drop in without a header panel swap/modification.
I also run Phillips for bulbs, including a swap to 9005 series in the fog lights. Three years, no overheating or housing/wiring melting. HUGE difference in light on the road, which is to be expected with a 55 (or 65, can't remember) watt bulb down low.
If you go one-piece, do NOT get MKM Customs ones (had Eagle Eye stickers on the housing), they're terrible. Beam pattern sucks and is scattered everywhere, and with them aimed so there's no scatter I was lucky to see 20' past the hood.
Old Aug 29, 2016 | 04:48 PM
CharlyG's Avatar
CharlyG
Just ordered the headlights at a1. We'll see if the oe turn signals will look ok with the new headlamps. I don't see why not, but....
Old Aug 29, 2016 | 10:39 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
It will be fine, I had my left over stock old 2004 headlights and I installed them in my old 2000 when I first got it. I later got clear corner turn signals but ran the amber corner lights for awhile. Only owned that truck 2 months or so before it was totaled though
Old Aug 29, 2016 | 11:39 PM
CharlyG's Avatar
CharlyG
They look fine to me. I just don't like the ugly faded plastic of the original headlight.
Old Aug 30, 2016 | 07:22 AM
IMASAP's Avatar
IMASAP
This is just my opinion, but I think it is the amber lens that dates the look of the truck. All a matter of taste though. I like the clear turn lens with an amber bulb.
Old Aug 30, 2016 | 08:12 AM
CharlyG's Avatar
CharlyG
At 65, dated is fine with me!
Old Aug 30, 2016 | 10:35 AM
IMASAP's Avatar
IMASAP
Haha....... 10-4 on that. I'm not all that far behind you.
Old Aug 31, 2016 | 08:14 AM
michaelg10's Avatar
michaelg10
I have been reading through the site for awhile and deliberating on this as well, I would prefer not to cut into the header panel but don't like my stock 2000 headlights either. I might go with the clear fluted like pirate says and be done with it.
