speedo (changed to a 4x4)
Old Aug 20, 2003 | 12:43 PM
stangboy_82's Avatar
stangboy_82
ok so I have an '85 f250 that was 2wd with a c6. I have sense swapped in a half ton front axle with older spindles to get the 3/4 ton wheels on it that all works great. I just yesterday got the new transmission in, np435, and the transfer case in it, np208, the truck that I pulled the tranny and t-case out of had 3.07 rear gears and my truck has 3.55 gears. my question is will I be able to use the speedo gear originally in my truck or is the gear inside the t-case going to be different from the one inside my c6 so that the gear on the cable will not work. I know I have to get longer cable that's already in the truck. I just don't know if I can swap the gears from the 2 cables and make it work. any suggestions will be appreciated.
