Questions while In the middle of EBPV delete
I am in the middle of an EBPV delete and I have turbo out and I bought a kit and I was curious if I should use any sealant between these two surfaces? I watched a video on YouTube and the kid said ford doesn't recommend any sealant, but he put some anyways.Should I use any? If so what? Orange permatex? Thanks!
I tried to put the turbo back on after work last night and didn't have the patience to hook up the band clamp to the y collector for the up pipes. I think I have it set up right, but is there supposed to be a small space between the turbo and the y collector or are they supposed to sit flush?
also I tightened the y pipes to the manifolds before I had the turbo on, so I had to loosen those bolts back up, should I get new nuts, or are they ok to loosen then re tighten?
Thanks
Thanks
z31freakify
Ford Truck Parts for Sale
12-12-2017 07:58 PM
sunny.richter
04-25-2015 03:16 PM
