Need drum diagram (missing parts)
So I need parking brakes on a 1985 f150 with a 9" rear end. Pulled the drums off and all the parking brake stuff is missing. Cable was cut and everything for parking brakes removed. I cant seem to find a diagram for an 80-85 or a 9" at all. Are they exactly the same as '86 up 8.8? Some one have a diagram handy? Thanks all.
My book is out in the shop right now but here are some photos of when I redid the Dana brakes on my 85 350. I am sure someone will provide a shop manual diagram before I get out there in the AM.
Update:
Removed photos.
Curiosity got the better of me so I went out to the shop. While the 85 shop manual has a good diagram of the 250-350's, they only have a completed picture for the 150 that I found. And while you can't see the parking brake setup very well it looks to be quite different from the photos I had posted so they won't help at all.
From memory it looks pretty close to what my old Mustang's setup is.
Update:
Removed photos.
Till a diagram is posted see if this will help.
It is the right rear drum brake setup of my 81 F100 w/9" rear.
The ebrake parts are:
Cross bar (just under wheel cly) with spring & washer. Runs shoe to shoe.
Ebrake arm- on the left side behind the shoe, the cross bar is pushed by the arm. The arm is held to the shoe with a clip, should also have a spring washer between arm & shoe.
Ebrake cable - this gets hooked to the bottom of the arm.
When I replaced the cables the replacements had springs, that push the arm back, were too long. So long I had a hard time to hook them on the arms. That would lead to not being able to apply the ebrake as the springs were is coil bind!
I cut I think about an inch off each side but may need to cut more. Will not know till I put the truck together and test it.
Dave ----
Dave ----
So I need parking brakes on a 1985 F150 with a 9" rear end. Pulled the drums off and all the parking brake stuff is missing. Cable was cut and everything for parking brakes removed.
I can't seem to find a diagram for an 80-85 or a 9" at all. Are they exactly the same as '86 up 8.8? Some one have a diagram handy? Thanks all.
Basic part numbers are the same. When the prefix & suffix are added to the basic part number, the full part number is attained.
Knew it looked the same as my Mustang, guess why change something that works.
https://onemanandhismustang.files.wo...drum-split.jpg
1980/83 F100 with 11" x 2 1/4" brakes / 1980/96 E100/150; F150 & Bronco // 1977/78 LTD/Grand Marquis / 1977/79 LTD II (not an LTD!)/Ranchero/Thunderbird/Cougar:
D7AZ-2A637-A .. Right Parking Brake Operating Lever / Obsolete
No Ford dealer or obsolete parts vendor has any.
D7AZ-2A638-A .. Left Parking Brake Operating Lever / Obsolete
B. F. WHITE MOTOR CO. in Stanton TX has 1 = 800-953-3321.
You could go all out -
New Ford Racing 9" Rear Axle Drum Brake Loaded Backing Plate Kit Pair 2 25" | eBay
Try Googling Mustang restoring parts and look thru what is given if they list any of the brake parts you need.
I came up with this site.
1970 Mustang Brakes | CJ Pony Parts
They list Ford trucks but did not see anything for brakes.
What size are your brakes and I may be able to measure the arms on my other 9" rear to check if same size.
Dave ----
Dave ----
DutchmanAZ
12-28-2012 11:37 AM
