Drops Cruise
Old Aug 19, 2003 | 11:27 PM
PSDMeg's Avatar
PSDMeg
Question Drops Cruise
Anyone had this problem? sometimes when I pass inferior vehicles on the freeway (usually a Dodge and usually going uphill) my cruise gets droped. This seems to happen as a result of using the turn signals. It's not turned off, just droped, as if I had hit the brakes. Punching the resume gets it back, but what a hassle.
Old Aug 20, 2003 | 03:50 AM
Quadzilla's Avatar
Quadzilla
Drops Cruise
It has something to do with the bulb in your 3rd brake light being burned out, I believe. It hasn't happened to me, but I've heard others explain it that way. Check your bulbs, and you'll probably find one burned out.
Old Aug 20, 2003 | 11:36 AM
theologian's Avatar
theologian
Drops Cruise
Mine did it forever, then I got rid of the Flatbed, so I could get to the third light, changed it, and now it behaves.. I did not realize this was the culprit until the problem was cured.
Theo
Old Aug 20, 2003 | 10:54 PM
PSDMeg's Avatar
PSDMeg
Drops Cruise
Thanks guys I will check it out
