Touch Drive and some questions
Old Aug 19, 2003 | 10:52 PM
rabidbandit302's Avatar
rabidbandit302
Exclamation Touch Drive and some questions
('88 Ranger Ext. Cab 4X4)
Here's the deal...I cleaned the motor on the T-case shift mech., brushes are clean and the motor runs when I used some aligator clips and a 12v battery I had layin' around to test it. For some reason I'm not getting power to the motor from the harness. Would this be caused by that fuseable link, or is it the Elec. Control Unit. I can hear the relays clicking, but it still doesn't show power to the motor when I have the meter hooked up. The position sensor works because when I manaully shift it with the shift motor off it registers the correct position on the overhead panel. I'm stumped
My other question is...what is the proper weight (80-90, 80-140?) of oil for the diff.?
Also, the computers at the auto shop keep coming up with my rear diff. as having a Limited-Slip...do all rearends for the XLT's come with a LS diff.?
Please help!!!
Thanks,
Chris
Old Aug 20, 2003 | 04:29 AM
rabidbandit302
Any ideas?
Old Aug 20, 2003 | 10:15 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Sounds like you have broke wire between the 4X4 ECM and the shift motor.I dont know for sure about the rear gear,but my 89 is a factor L/S Dif.with 4.10 gears .YEA it came that way!!
Old Aug 20, 2003 | 11:21 AM
Rand's Avatar
Rand
Post your rearend code off your door sticker.
Old Aug 21, 2003 | 12:26 AM
rabidbandit302
Thanks guys...I'll check the wiring for continuity and hopefully I can find the prob. I figured out the diff code...8.8 open 3.73. Bummer, no LS
