Edge chip 3.5 eco boost
Old Aug 16, 2016 | 05:26 PM
rods04f150's Avatar
rods04f150
Has anyone had experience with using an Edge Gas Evolution CTS2 Tuner? I just bought a 2016 F150 XLT with the 3.5 EB. I wish Ford would have used some sort of gauge for the boost PSI.
Old Aug 16, 2016 | 07:04 PM
QwkTrip's Avatar
QwkTrip
Not that particular product but I had a different Edge product for a diesel (came with the truck I bought) and it was a complete pile of junk. Turns out my experience was a majority, not the minority. I will never buy an Edge product after that experience. Can't fault them on after-sales support though, they do own up to their problems and try to take care of customers.
Regardless of all that, if you're going to tune an Ecoboost then you are looking in the wrong place. Get a custom tune from a place like MPT, Leading Edge Tuning, or some other place that has good skills tuning an Ecoboost.
Old Aug 16, 2016 | 11:49 PM
onug's Avatar
onug
The display on the lariat trim levels (and higher) do have a boost gauge. Buy a ScanGaugeII if you're just looking for boost. I watch boost on mine, plus three other parameters.
Old Aug 18, 2016 | 04:02 PM
rods04f150's Avatar
rods04f150
Thanks ONUG I looked into the ScanGauge II and that is exactly what I needed. So I ordered one.
Old Aug 18, 2016 | 08:39 PM
onug's Avatar
onug
Nice! Glad to help. Mine actually shows a negative boost value until I stop feathering the throttle. But my dash gauge hits about 1lb of boost at the same time as the ScanGaugeII, so I think it's pretty accurate. Have fun!
Old Aug 21, 2016 | 06:49 AM
Rexp's Avatar
Rexp
If you are towing you should have a pyrometer, so you don't melt your pistons or valves,
Old Aug 22, 2016 | 07:48 AM
QwkTrip's Avatar
QwkTrip
That is diesel talk. All you need with a gasser is a good tune. The Ecoboost already has sensors and diagnostics out the whazoo from the factory, including dual wide-band O2.
Old Aug 22, 2016 | 09:15 AM
tvsjr's Avatar
tvsjr
Yep... the EBs were built to be bulletproof. If they can put them in squad cars with cops who drive the crap out of them, they'll be just fine.
Old Aug 30, 2016 | 02:35 PM
Rexp's Avatar
Rexp
[QUOTE=QwkTrip;16515415]That is diesel talk. All you need with a gasser is a good tune. The Ecoboost already has sensors and diagnostics out the whazoo from the factory, including dual wide-band O2.
nothing like a good post police.
evidenty all folks don't know what a pyrometer is, not a tuner, sensor or diagnotics
Old Aug 30, 2016 | 10:23 PM
QwkTrip's Avatar
QwkTrip
What the heck...? I think I just witnessed the grown-up version of a little kid that is stumped and yells out, YOU'RE STUPID!! and stomps away.
The gasoline engine has a throttle blade that limits air supply to the engine, and there is an O2 sensor that monitors air/fuel ratio. The exhaust temps are managed by proper air/fuel ratio and spark timing, which is governed by the tune. The diesel engine does not have a throttle blade, does not have spark plugs, and the foot pedal controls fuel supply, and air/fuel ratio varies by a huge amount. Exhaust temp is monitored because you don't know air/fuel ratio and whether the engine is running too rich.
---> Again, all you need with the Ecoboost is a good tune.
Old Aug 31, 2016 | 02:14 PM
Rexp's Avatar
Rexp
i am stilll here you can not run ME off, i said nothing about anyone being stupid. maybe i should have. what exactly makes some folks think they should be one to correct every one else. I will give you plenty to watch for.
I think i just witnessed a ?
Old Aug 31, 2016 | 07:06 PM
QwkTrip's Avatar
QwkTrip
Well, I see you're not talking about pyrometers any more. That's an improvement.
Old Sep 1, 2016 | 06:03 AM
Rexp's Avatar
Rexp
would you like to talk about them? i like the 3" with red back light, large white numbers.
Old Sep 2, 2016 | 08:23 PM
71_340's Avatar
71_340
I think you were corrected because your advice was wrong. You should take it as constructive criticism and learn from it.
Old Sep 2, 2016 | 09:23 PM
QwkTrip's Avatar
QwkTrip
Reps sent for that post
