Pressure high in the fuel pump to carb line? If it's too high then the needle and seat can't hold the gas from entering the carb's bowl. And that fuel will come out the bowl vents. If you have an electric fuel pump then maybe the pressure regulator not working right. If mechanical pump then isolate heat from the pump to carb line. I have heard heat in the gas in that line, on the verge of vapor lock, can cause higher pressure.
On the different temp exhaust manifold, my 1st reaction was plugged,smashed, or kinked R/S exhaust pipe or muffler if you have duals. Did you run over something in the road recently?
Absolutely no kinks in the exhaust as its still stock other than a new muffler. And replaced the new seat with the old one and no more boil over but there's still a lot of pressure there when it sits
Still sounds like a flapper. It doesn't matter if the part # is 1969, they've used the heat crossover butterfly since at least 54 when the first Y block came out.
The flapper isn't exactly part of the manifold, it's sandwiched between the manifold and header pipe.
Damn I'm ignorant I'll go have another look in a few as I just grazed over it when I looked earlier
Willow has a point here. The flap was on the right side of the motor if it had one. In it's own housing sandwiched between the exhaust manifold and the exhaust pipe. If it were closed or mostly closed it would try to send that side's exhaust under the carb and over to the left bank. This passage usually gets plugged up. So then the exhaust manifold tries to get rid of the exhaust but can't for the most part. That would heat it up.
I think I see what you're talking about now but I don't see how I can fix it? Take off the manifold I'm assuming?
Not necessarily. If your rig has one it is in it's own housing. Lawd knows if your engine and exhaust manifolds are factory original or something the PO installed. If it does indeed have one, disconnect the exhaust head pipe and remove the flap and housing (exhaust thermostat control valve) assembly from the exhaust manifold. Clean all the rust etc off it. Soak the shaft and bushings where it pivots with your favorite penetrant.
I'll be ordering headers for the truck so when I replace these logs I'll fix the valve up refurbish them and keep them for a rainy day. But appreciate the help! I'm sure this is my whole issue
